MP7502sp and 6001sp - large white line problem
Re: MP7502sp and 6001sp - large white line problem
Hi, The pcl5e bringing blue screen is due to recent window update. Have a look at this link
Windows 10 update is causing havoc with some printers | TechRadar
Some of my customers using pcl 5e have reported same.
Sent from my LLD-AL10 using Tapatalk -
Hi Juggy, thanks for reply
I solved that problem updating W10, but now I'm still forced to use PCL6 v4 driver, that makes my printer really slow, and it destroy my productivity. If i use pcl 6 or 5e driver, i get a large white line in the middle when i print an image.Comment
Hi,
Also today 3 different clients called md have same problem, on bizhub machine and canon, i told him. Its a windows problem but still didnt find solution.Distinguished road makes you jewel in roughComment
"Caro Gigi di Bari", to me however, as I read "thick white line" I don't know why? it will be professional deformation, I was reminded of the corona wire cleaner motor that is enchanted around the course ... then I don't know ... LOL"I'll be back"Comment
what kind of communication port are you using? I recommend a fixed ip address, no wsd, do the latest firmware updates, use pcl6 and for the white lines problem send us a print photo from pc, one with the printer configuration from the user tools.
it could also be lint in the developer unit stopping the toner in the magnetic rollerComment
The fact that all the printers suddenly started to have problems on Saturday makes me think that it is due to the famous update that caused the blue screen, which however was solved with a fix two days ago, while the problem of the thick white line remained.
Since Saturday I am also having problems with color printers (two Aficio MPC2500s), which when I print pdfs, sometimes they pull me out sheets full of nonsense alphanumeric codes.
I'll try to do a system restore and / or maybe update the firmware on all printers, but I'll have to find the files.
It doesn't happen when i do normal copies or print pdf.Comment
I've had several customers complaining about white band when printing, it only happens when printing JPegs, I have advised them all to uninstall the latest windows update, although, I believe, Microsoft have now brought out some hotfixes. The latest windows update has caused no end of issues with printingThere are 10 types of people in this world, those who understand binary maths and those who don'tComment
Hi Gigi,
Unfortunately I don't have a solution to your problem, but I hope this saves you from future trouble.
I have set all of the computers that work is being done on in my shop to get the least amount of updates as possible, there used to be an option under Settings>Update & Security>Windows Update for Windows to not install feature updates as soon as they are available. My computers mostly install small, security updates frequently and only the large semi-annual updates, well, semi-annually.
It may be luck, but I haven't had an issue with any drivers or software breaking so far. It could be worth checking out if you can still change the update frequency so Windows doesn't install an update as soon as it is released, since it can cause issues. If you install them after they've been out for a while, usually most of the issues are fixed before they are applied to your machine.Comment
Hi Gigi,
Re: MP7502sp and 6002sp - large white line problem
Hi, just go thru the below link. Image defects are also caused by Microsoft update. They are coming out with patch to solve this.
Windows 10 printer glitches: Microsoft issues second out-of-band patch | ZDNet
Regards
Juggy
Sent from my LLD-AL10 using TapatalkComment
Microsoft released the patch for this problem. You can download it here: Microsoft Update Catalog
Tried yesterday and it works.
Inviato dal mio SM-G935F utilizzando TapatalkMemento Audere SemperComment
