MP501 VOID Area
  • sandmanmac
    • 3981
    MP501 VOID Area
    Hi All.
    I don't normally post problems prior to visiting the customer to assess. I try and resolve the issue myself first, but I have very little experience with these boxes and frankly there doesn't seem to be much discussion in the forum about them either.
    Customer has sent me the attached picture showing quite a wide void running the length of the page for any type of output. (The background that appears on the sample is not part of the problem as far as I'm aware).
    The machine has about 80K on it. It has not displayed any recent SC codes as far as I know.
    It could end up being something silly, like an obstruction of some sort, but I just thought I'd reach out in advance in case there is any history on it.
    Thanks!
    MP501 sample.pdf
    • 37489
    Re: MP501 VOID Area
    Toner cartridge dumping toner on the laser shield glass. Or a pile of toner on the opening of the PCU that the laser scans through.
    • sandmanmac
      • 3981
      Re: MP501 VOID Area
      Thanks Tim.
      Yes, I'm thinking its a collection of toner somewhere myself. I neglected to mention that he did own up to using compressed air that seemed to resolve it for a time. I hate it when people do that!
      I'm thinking (1) the issue wasn't this bad before and (2) he loosened up a bunch of dust and toner and then the fans circulated it around the laser shield glass, (or something like that) and made the situation much worse.
      Either way, I feel like it should be fairly straight forward
        • 37489
        Re: MP501 VOID Area
        Originally posted by sandmanmac
        Thanks Tim.
        Provided the compressed air didn't force toner/dust inside the laser housing.
        • sandmanmac
          • 3981
          Re: MP501 VOID Area
          Agreed!
          I've looked into the laser removal procedure on it and am not too anxious to get involved in that if I can help it
            • 37489
            Re: MP501 VOID Area
            Agreed!
            If it is anything like the previous models, that paper receiving tray is a bitch, both getting it off and putting it back on. There were a model or two where you had to remove it in order to disconnect the fusing unit from the power supply in order to PM the fusing unit.
            • sandmanmac
              • 3981
              Re: MP501 VOID Area
              I think you're thinking about the mp201/ 301's. I know what you mean, but I actually do a lot of those, and it's pretty easy now.
              In this case you have to remove the entire scanner assembly and Op panel (I think) in order to remove the exit tray, and access the laser, that's why I'm REALLY hoping he didn't go too crazy with air can
              • RMC8112
                • Nov 2019
                • 38
                Re: MP501 VOID Area
                Ive seen this before. Check the drum unit, and charge roller. The cleaning blade for the drum has something stuck and is wiping the toner from the drum. When i had this happen to my customer, i took the drum apart, (I know you're not supposed to on these units), but i found a label stuck between the blade and drum.
                • luca72
                  • Oct 2017
                  • 1778
                  Re: MP501 VOID Area
                  Hi All.
                  Thanks!
                  [ATTACH]48623[/ATTACH]
                  so at first glance, there seems to be a toner or developer leak that has accumulated in front of the laser slot on the pcdu,
                  then, if you say the customer blew in it, anything could have happened
                  "I'll be back"
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Re: MP501 VOID Area
                    Hi All.
                    Thanks!
                    Remember these is a Kyocera machine could be toner on laser glass or dev assy check mag roller good luck sandy
                    Regards Mark
                    • tsbservice
                      Field tech
                      • 8013
                      Re: MP501 VOID Area
                      Looking at sample it goes slightly faint through image areas, very likely dirt on laser path as many other techs mentioned. You should furthermore probably explain customers have to suck it instead of blowing it...just kidding
                      • sandmanmac
                        • 3981
                        Re: MP501 VOID Area
                        Well......as I told the customer, I wish I had a nickel for every time I went to the call and the problem had mysteriously resolved itself!
                        It was working perfectly upon arrival. I did remove dev unit from the drum section to see if I could see any remnants of paper/ label, etc, that may have been an obstruction. Nothing.
                        The machine is very clean inside, and I I said has under 80K on the meter. I ran nearly 100 pages through, and no defects, and no SC codes logged since 2016.
                        Time will tell I suppose.
                        Thanks all for your suggestions!
