W2400 Drum seal
  • mikadonovan
    • May 2008
    • 2931
    W2400 Drum seal
    Hey, everyone. I have a w2400 with a seriously warped/leaky lower cleaning seal on the drum unit. According to the parts catalog it comes as an assembly with the casing itself, which is a little hard to believe.
    Does anyone have a part number for the seal itself? Thanks.
    NEVER ASSUME ANYTHING
  • GIUBOSS
    • 1436
    Re: W2400 Drum seal
    If it is not in the spare parts catalog (without ordering the entire part) I don't think you will find it around unless you look for it in similar spare parts catalogs, even for different models. I happened to adapt a gasket available in the catalog of the Dsm745 and I adapted it to rebuild the damaged type 1027 pcu.
    • luca72
      • Oct 2017
      • 1784
      Re: W2400 Drum seal
      it is really frustrating to have to replace the whole part for a stupid seal, the problem, I guess is very long, it happened to me on a frame of a 4054, and I was able to reuse that of a new unused frame of a dsm735, however on amazon there are some films (to be cut out) that could be fine, they also sell rolls of excellent 3m double-sided tape of the necessary thickness from 1mm up, with a little concentration it would be a great job
      "I'll be back"
