FUSER UNIT RICOH MPC2003
  • skinnyb
    • Jul 2008
    • 291
    #16
    Re: FUSER UNIT RICOH MPC2003
    I use the D150 sleeve across the board, all the other parts are interchangeable like mga has said. I even had a rebuilt 45/55PPM unit that I put in a 3003 a while back, just swapped out the bottom plate and it has been running fine for over 6 months now. That said, the 2003 sleeve unit heater I would be afraid would not put out enough heat on a 55ppm device and code out on you.
    • Pixtech Frameworks
      • May 2020
      • 238
      #17
      I will just swap sleeve then because swapping D150 assembly to 5503 is a 50% chance, so to avoid throwing up codes and customer calling all time.
      Thanks for the clue.
      • Debs1964
        • Oct 2010
        • 1690
        #18
        D150 is the correct part number for the 5503, this is the higher wattage part, and can be used on all 03 models
        There are 10 types of people in this world, those who understand binary maths and those who don't
