FUSER UNIT RICOH MPC2003
  • Pixtech Frameworks
    • May 2020
    • 238
    Hello Everyone,
    I have a customer who uses Ricoh mpc5503 and the Fuser Unit sleeve got damaged. Trying to swap fuser unit from 2003 to 5503 unit doesn't fit in. What could be the problem?? The option now is to transfer sleeve from 2003 to 5503.
    Has anyone experienced this before??
  • luca72
    • Oct 2017
    • 1748
    Re: FUSER UNIT RICOH MPC2003
    Originally posted by Pixtech Frameworks
    Hello Everyone,
    have never tried this crossing, but it must be a hard job, I don't think it's okay, if your problem is the budget and it is not electrically damaged, you can do the minimum wage, just replace the sleeve film, and the pressure roller, try a couple, and I had no problems, with about 100 euros you can manage.
    however, the pressure roller is the same, but the heater has different codes
    "I'll be back"
      • May 2020
      • 238
      I will swap the fuser sleeve from the 2003 to 5503 if that's the case. I wonder whh Ricoh did it that you cross change fuser unit from 2003 to 5503 but uses same sleeves and pressure roller.
      • TonerMunkeh
        Professional Moron
        • 3865
        The sleeve unit is physically different between the two and the lamps are different wattages.
        Hit it.
        • copier tech
          • 8131
          Hello Everyone,
          I use the same sleeve for all the xx03 series.
          In what way did yours 'not fit'?
            • May 2020
            • 238
            They use same sleeves. I what I mean is if one has 03series machines you can easily interchange fuser unit without changing anything from each other.
            • davel
              • Oct 2011
              • 1095
              Fuser is different, read your manual.
              • Debs1964
                • Oct 2010
                • 1690
                You can use the 5503 sleeve in all 03 models, but it's not advisable to use the one from the slower devices in the 4503/5503 as the lamps are a lower wattage and likely to blow. The fuser units are different and will not fit in the wrong model
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  +1 they all will work I carry one number and use as and when any 03 series just swap bottom fuser cover or take pin out out copier it will work
                  Regards Mark
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    I carry the d150
                    Regards Mark
                    • mrwho
                      Major Asshole!
                      • 4299
                      You're talking about just the D150 sleeve, and not the entire fusing unit, am I correct?
                      Mascan42
                      Ibid
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Yes I carry the d150 sleeve assy but all the other parts for the metis series ie mpc2003 to 6003 are the same part numbers apart from the sleeve and the bottom cover on the fuser assy
                        Regards Mark
                        • sandmanmac
                          • 3979
                          Hello Everyone,
                          My guess is it got damaged from all that " counterfeit" 300 g/m2 paper.
                          RICOH MPC5503
                            • May 2020
                            • 238
                            No, this is another customer whose 2003 has a PCB issues, so trying to interchange fuser unit from 2003 to 5503 doesn't fit in.
                              • May 2020
                              • 238
                              I thought of these also. I my thought is if the D150 assy lamp will not blow since am interchanging from 2003 to 5503 which is higher model.
