Re: FUSER UNIT RICOH MPC2003
I use the D150 sleeve across the board, all the other parts are interchangeable like mga has said. I even had a rebuilt 45/55PPM unit that I put in a 3003 a while back, just swapped out the bottom plate and it has been running fine for over 6 months now. That said, the 2003 sleeve unit heater I would be afraid would not put out enough heat on a 55ppm device and code out on you.
