Martini C1 Aficio 1075: background only on a part of the 1st copy
  • stani
    • Jan 2013
    • 49
    the first 5cm/2 inches of the first copy/print have dark background, next pages are ok. The best way to see the problem - to print out copy counter. If you wait about 5 minutes, the first print after that time will also have first 5 cm with background. By copying it is necessary to wait longer. The counter is about 3 millions. I have changed: drum, blade, brush, corona wire, grid, developer, transfer unit. Maybe drum grounding?
  • Polo-022
    • Sep 2007
    • 486
    Re: Martini C1 Aficio 1075: background only on a part of the 1st copy
    Always the Drum!
    Re-replace it.
    • GIUBOSS
      • 1436
      Genuine drum? Have you tried in A3 to see if the defect is repeated throughout the sheet? Did you also clean the scanner section thoroughly? That old machine might have a dirty laser too
      Another attempt is to wipe the drum with a dry cloth to remove any invisible stains such as halos
      • luca72
        • Oct 2017
        • 1780
        so on two feet, almost certainly drum, (evaluate you based on you have pm) then connect the heaters and clean the air filters, (all)
        "I'll be back"
        • mrwho
          Major Asshole!
          • 4299
          My bet is also on the drum. Known problem on this machine series.
          Mascan42
          Ibid
            • 37508
            When the drum surface starts to deteriorate, it can not reach full charge quickly enough and results in the background on the lead edge of the first page after setting idle. Ricoh drums for this model are rated for 700K. the rating is based on normal usage with letter size paper long edge fed. Longer paper lengths and small jobs increase the average drum rotations per page shorten the drum life. Non genuine Ricoh drums WILL fail sooner and WILL actually cost you more in the long run. Rebuilding the charge corona may give you another week or two.
            • luca72
              • Oct 2017
              • 1780
              This Is porno-tec...LOL
              "I'll be back"
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Did you replace with NEW oem or used
                Regards Mark
                • stani
                  • Jan 2013
                  • 49
                  Actual drum is not original ricoh, I will replace it once more with original one. Drum meter reading about 25000 pages. Scanner section cannot be the reason for the fault as the error is on the counter printouts also.
                    • 37508
                    If in fact it is an actual NEW Genuine Ricoh drum for the martini series, then you have a bad HVPS, bad corona or connection between the two. Bad drum ground would produce a solid black band anywhere on the page and some times the entire page and an occasional Service Call code.
                    • satins
                      • Feb 2021
                      • 89
                      Kindly check the SP Mode value for 7403 - 01.
                      the bottom value will present you with the latest code along with the time.If you have a code related to id SC 311,326, 306 etc.
                      It surely means that you need to change drum or charge corona assembly.
                      Good luck.
                      • bat
                        • Sep 2008
                        • 140
                        The problem is Corona Assembly.
                        • stani
                          • Jan 2013
                          • 49
                          Many thanks, it was the not genuine drum
                          • mrwho
                            Major Asshole!
                            • 4299
                            Thank you for the feedback.
                            Mascan42
                            Ibid
