Ricoh MPC2051 jam code J064
Regards Mark
https://copierservices.simdif.com -
Re: Ricoh MPC2051 jam code J064
It all comes out of memory. I've been working on copier and other office equipment since March 1972. In the days of the early non BrandX plain paper copiers I even designed auxiliary paper trays and coin op attachments for a couple of makes.Comment
I had to dissect the machine agin, I felt an irresistible urge to know the exact processor in it
The processor is the lower part of the two missing it's heat sink.
It's an Intel Celeron at a paltry 600MHz with 512KB kache. 130nm process node, launched in 2003, so it was already an old (and cheap) part when this printer was launched in 2011.
It contains just 77 million transistors, compared to modern desktop processors containing around 10 billion transistors.Comment
Generally once I write some down on paper I will remember it, one way or another. As an example, when growing up, I could study the weekly spelling list all dat every day for a week and still not be able to remember all the words. Copy each of them to another sheet of paper and they were locked in. As a result I always did excellently on spelling tests but when it came to the annual scholastic achievement I was usually near the 70th percentile as opposed to 94th to 99th on everything else.Comment
I like very much designing stuff. I dont get to do it that much currently.
Previously when I worked on stationary systems I designed and built some refrigerated equipment.
Pics of a box with ice water for chilling hot products. It can cool 300kg products from close to 100 degrees down to close to zero degrees in less than one hour. It has a storage of about 300kg ice on the tubes in the last pic. That ice causes the water temp to increase only a couple degrees when the hot product is put into the box. The tubes are in the lower half of the box. You can just see the bottom plates in the left side of the last pic, one plate removed to see the cooling tubes. Total volume of the box is about 1600 liters. Panels is made of stainless steel plates, 0,7mm thick, glued with a PVC foam core into 52mm thick panels. The panels are then glued together to form the box. The pump circulates up to 10l/s of water, you can see the water circulating in the pics. The pump is controlled by a VFD so the circulation can be adjusted from very low up to max. At max the water splashes over the edge of the box though.
I designed and made this box in about 2003, together with the cooling system for the box and many other chilled rooms, cabinets etc for that installation.Comment
I take it that you have never had the joy(sarcasm) of working on an internal finisher. When they worked, fine, but when they had problems it became a whole new experience, especially the one used on this model.Comment
OR you can check out my profile on fakebook Philip Brink.
I use the same Gmail addy there also.
Sent from my SM-G960U using TapatalkComment
ah just kidding, all in good fun.🤣Comment
Attached Files"I'll be back"Comment
I read in the Ricoh manual that they advise the use of a grease on the fusing unit that must be made of 50 percent gold dust and the reimainder of platina and silver and some other exotic elements.
It is Barrierta S 552R.Comment
Is this the same stuff that is advised to cover outside of engine injectors with when replacing them?
look, maybe I didn't quite understand your question (?) however, if you mean that special oil that you put on, when you replace the camshaft and the engine head tappets, it's not that, what you mean is an oil of synthesis...the Ricoh Grease cost like cocaine..lol...this cost 11 euro"I'll be back"Comment
