Do MP3054 support Windows Server 2019 SMB 2 or 3?
  • windcopier
    • Apr 2019
    • 51
    Hi,
    May i know did anyone try before for file sharing to Windows Server 2019 in MP3054 ?
    Is it work?
    Because when i try to browse and connection test, it show that unable to find the specific path.
    As i know MP3054 did support SMB2 above.
    Thank you.
  • rthonpm
    • Aug 2007
    • 2853
    Re: Do MP3054 support Windows Server 2019 SMB 2 or 3?
    The 54 series support SMB 2 and 3, though if SMB encryption is turned on at the server level it will not be able to connect. If it turned on at the share level, there is no issue. You may want to make sure all firmware is up to date and that the network settings and credentials are correct.
    The browse feature likely will not work because it is an SMB 1 feature, but going straight to the folder and doing a connection test should work without issues.
    • copier tech
      • 8144
      Originally posted by windcopier
      Hi,
      Is it work?
      Thank you.
      As stated below SMB 2/3 is supported but you may need to update the firmware.
      • windcopier
        • Apr 2019
        • 51
        ok. thank you , i update the latest firmware first.
        • windcopier
          • Apr 2019
          • 51
          ok. at least i can confirm it does support smb 2/3.
          update the firmware to see how to result.
          thank you.
          • windcopier
            • Apr 2019
            • 51
            I had just update the Firmware and able to work.
            • anothertech
              • 1768
              Too many people are out there troubleshooting machines, spending time and money, when they just need a firmware update. I see it all the time.
                Well Personally I try to follow the K.I.S.S. principle at first.
                And 9 times outta 10, it's the inexpensive parts that fail first.
                The way customers yank the power cord trashes firmware and apps on the copier.
                  • 37483
                  A quality power protection with the correct rating can be one of those "Pay me now or pay me later" items. Usually cost a lot less than a major PCB.
