Re: SMB Scan to Amazon Web Services (AWS)
The issue may be that the AWS gateway is set for SMB encryption. Ricoh machines can scan to SMB shares with SMB encryption, but it has to be set at the share level, not at the server level. It's possible that Amazon's implementation is more or less seen by the machine as a server-side setting. SMB encryption is only available with Windows 8 and higher as it's a part of SMB 3. If you try connecting to a share set for it with an older OS you just get a username and password prompt that won't allow you to connect.
Check the information here to see if it's of any help: Creating an SMB file share - AWS Storage Gateway
Sent from my BlackBerry using Tapatalk
