Aficio 2051sp SC818
  • JJesusGarcia
    • Jul 2025
    [Error Code] Aficio 2051sp SC818
    Hi
    I have problem with a copier recently start with 818 error message, i tried change HDD, In some forums I found that need to upgrade or reinstall Firmware, could you help me with this files, I tried register in Ricoh page but nothing happens they not answere my request
    jesus_garcia_zamora@prodigy.net.mx
    Model Aficio 2051sp
    regards
    • 37495
    Re: Aficio 2051sp SC818
    Originally posted by JJesusGarcia
    Hi
    Model Aficio 2051sp
    regards
    Maybe you should start with getting a service manual as SC818 has nothing to do with the HDD. It is a controller board error and may require replacement of said board as well as system firmware. Give it a couple of hours and I am sure 'copier tech' from the UK will post his website for obtaining. The service manual will also tell you how to update the firmware. Do it wrong and you end up with a boat anchor.
    • copier tech
      • 8145
      Hi
      Model Aficio 2051sp
      regards
      Fit the original HDD back this may not be the issue, delete any print jobs in the queue, remove the network cable & then update the firmware.
      • Code: 818
      • Description:Watchdog error
        While the system program is running, a bus hold or interrupt program goes into an endless loop, preventing any other programs from executing.
      • Causes:
      Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
      • luca72
        • Oct 2017
        • 1780
        Hi
        Model Aficio 2051sp
        regards
        I did not understand, but are we talking about the mpc2051?
        if so, try to disable java auto-start, from user tools, upgrade the firmwar, if it persists try to disconnect the cards behind, clean card and ram connectors, try various reset sp801-xxx (with engine you have to re-enter some data), if it still does, there is an electronic problem, and you need to test by replacing the boards
        "I'll be back"
        • fshead
          • 2376
          mp2051 is a bw same engine as the mp5500/mp6500.
          way old and i have not seen one in 5-6 years
