The copy in the MPC 4502 is deviated
  • phucnguyen
    • Jan 2021
    • 17
    I was using this machine, suddenly it printed out the wrong color, I used 2111 but still not, everyone save me, thank youban-test-mau-bi-lech-photocopy-ricoh-mau-mpc-4502.jpg
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
    [/COLOR]
  • ridgemill
    • Sep 2017
    • 187
    Re: The copy in the MPC 4502 is deviated
    Perform a color registration in User Tools > Maintenance
    Or, go into System SP and perform Forced Line Adjustment, under SP2 Drum
    If it keeps re-occurring, you may have a fault transfer belt, faulty ID sensors, drums not locking into place, or a loose connection on the laser unit.
    • GIUBOSS
      • 1407
      Originally posted by phucnguyen
      I was using this machine, suddenly it printed out the wrong color, I used 2111 but still not, everyone save me, thank you[ATTACH=CONFIG]48915[/ATTACH]
      [/COLOR]
      [/COLOR]
      first what did you clean the ID sensors?
      • luca72
        • Oct 2017
        • 1759
        [/COLOR]
        [/COLOR]
        try to clean id sensors, manually check that the photoconductors are free to rotate and not hard, perform forced alignment, update firmware and re-run calibration and registration.
        "I'll be back"
          • 37422
          More often than not just properly cleaning the ID sensor assembly will correct the problem.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            [/COLOR]
            [/COLOR]
            Looks like someone has done memory all clear. Registration is way out do ld line adjustment start from d to a
            Regards Mark
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              [/COLOR]
              [/COLOR]
              presuming you a tech and know how to enter SP mode and did the 2 - 111 - 03x2, 01x1. Cleaned the ID sensor ass'y (machine is off) inspect the ITB ass'y for possible worn out, cleaned it if found some dried toner. inspect PCU's seems CMY is out of position. usually sp 2-111- xx can resolve the issue if no luck and have some ITB unit to swap then execute sp 2-111-xx for isolation.
              good luck sir. cheers
              fix the customer first then fix the machine... its simple and makes life more easy.
