Problema MP 501
  • fvargasbarrote
    • Jun 2020
    • 4
    [Jamming] Problema MP 501
    Good afternoon people.
    I have a problem with an MP 501, I will try to explain as much as possible what happens in it.
    When we turn on the printer, it activates an axis that is above the duplex, that axis when it rotates from the pressure in the roller, there is a sensor there, but that axis does not stop rotating, we change the plate that it acts, fusion, some motors and it does not for never. The only plate we didn't change was BICU. I wonder if anyone has any other tips?
    thanks!
    Re: Problema MP 501
    thanks!
    plate BICU? do you mean the PCB BICU?
    • anothertech
      • 1768
      Re: Problema MP 501
      You have got to a better job describing the problem, do you have an error code or a jam code?
        • 37481
          Re: Problema MP 501
          Yeah and pics of the item would help also.
          • fvargasbarrote
            • Jun 2020
            • 4
            Re: Problema MP 501
            Good morning folks, on the interlocking topic that occurs in MP 501 (duplex only).
            I will wake up better as requested what already approved in it. The actuator (M2812833 ACTUATOR ENVELOPE) rotates constantly.
            Jam code: Jam 077 - (Paper exit sensor full: Late jam (In paper feed
            duplex unit)
            Sensor cleaning: M2812841 OPT SP PARTS SENSOR
            Cleaning the sensors on the board: M2812837 - HIGH VOLTAGE SP
            Replaced Plate: M2812837 - HIGH VOLTAGE SP
            Fusion changed (for testing only).
            Firmware update.
            I send the image of the axis sensor that keeps rotating constantly.
              Re: Problema MP 501
              Slim said to translate into english from your native language
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: Problema MP 501
                Very sorry iam struggling to understand what you are talking about in your wording can you try to be clearer are you a engineer.
                Regards Mark
                  Re: Problema MP 501
                  he claims to be a tech:
                  About fvargasbarrote
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Re: Problema MP 501
                    I did notice that that's why I asked.
                    Regards Mark
