No options in system settings
  • Debs1964
    • Oct 2010
    • 1693
    I spoke to a customer today who needs to change the host name before the device goes into the network, so I was trying to talk him through changing it on the panel, this is a new install, and this is a demo machine, when he goes into system settings, the only tab available is admin tools, and the only option in there is service mode lock.
    I did get the host name changed using the WIM, but has anyone got any ideas as to why the tabs are missing
    There are 10 types of people in this world, those who understand binary maths and those who don't
    Re: No options in system settings
    [ATTACH=CONFIG]48949[/ATTACH]
    Hi Debs1964... can wee get the model # of this device?
    • Debs1964
      • Oct 2010
      • 1693
      • mikadonovan
        • May 2008
        • 2931
        Maybe it has a custom security level set.
        NEVER ASSUME ANYTHING
          • 37556
          I wonder if someone has set separate Machine and Network administrators. I don;t know if I would tell a user how to get into Supervisor in order to check Admin names and access.
          • Debs1964
            • Oct 2010
            • 1693
              • 37556
              I would have thought that you would be able to see the options, even if you couldn’t change settings. If admin authentication is turned on and you don’t login you can still see all 6 tabs
              My experience in the field had been that the front panel you can see all the tabs with denied options greyed out. From WIM you could only see what you have access to. Things may have changed with the newer model since I retired.
              • Debs1964
                • Oct 2010
                • 1693
                • tsbservice
                  Field tech
                  • 8030
                  System reset, Factory reset, Initialize all.
                  Don't know what Ricoh calls reset to factory default but I have had resolved(other brands) some really odd balls this way.
                  Edit:
                  Of course you don't want to do it on live and working machine especially remote. Just some food for thoughts.
                  • Debs1964
                    • Oct 2010
                    • 1693
                    Edit:
                    • tsbservice
                      Field tech
                      • 8030
                      Yes gut feeling. Or call it The Force
                        • 37556
                        It is a pain when you can't be hands on.
                        • tsbservice
                          Field tech
                          • 8030
                          Absolutely. We have something called remote panel. It's literally as you're sitting in front of the machine and touching panel.
                            • 23010
                            It's just so much easier to make those changes via the web interface, I wouldn't do it any other way. Like editing the addressbook: Sure you can use those itty bitty buttons on the panel, or you can use your comfortable, full sized keyboard. Why do it any other way? =^..^=
                            • Imprestik
                              • Aug 2012
                              • 297
                              If this is ex demo they have locked down the machine admin for some stupid reason and made multiple administrators for this particular device.
                              I would suggest you login as a supervisor, change all passwords and start from scratch by creating 1 administrator that has access to machine, network and user administration
