SOP - Wifi/Bluetooth won't stay on
  • MBZ6301
    • Aug 2016
    • 42
    I'm aware this is going to be the most obvious setting, but it's something I've not come across. When turning on Wifi and Bluetooth in screen features, both Wifi and wireless direct are greyed-out. Bluetooth isn't, however after turning it on, it resets to off once you leave the menu.
    I'm guessing as the machine (mpc2004) was from another company they've likely changed a setting I'm not finding?
    Firmware's up to date, administrator + network settings cleared, and I've compared logging data/WIM stuff with another 2004 that's got no issues.
    Any clues? Am I being thick? Cheers
  • luca72
    • Oct 2017
    • 1780
    Re: SOP - Wifi/Bluetooth won't stay on
    with us the bt, and the wifi direct, nobody uses it (pure casuistry) so I don't have a lot of experience on these issues, but I would like to suggest to you in the first place that:
    it is better to set the panel in "slow start" mode, that is, when the machine is turned off, the panel turns off completely, and is not in standby, this allows, not only in copiers, to avoid a whole series of problems of " strange packaging "that the android panel os can suffer.
    I understand that wi-fi direct and wi-fi cannot coexist at the same time, therefore, either one goes, or the other goes, like on the smartphone, the printers, or the bluray player....f you haven't, I suggest you also update the firmware of the sop panel
    "I'll be back"
    • MBZ6301
      • Aug 2016
      • 42
      Cheers bud,
      Yeah I've updated SOP, and normal boot up mode, both making no difference. We only really change/turn on the settings in order to make the most of the connector app
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Bluetooth isn't standard on this machine I've never seen one fitted
        Regards Mark
        • luca72
          • Oct 2017
          • 1780
          vade retro, bluetooth! just go looking for empty calls...and boring phone calls
          "I'll be back"
