mpc6004ex as a network device for scans
  • digicor
    • Jul 2008
    • 1159
    i can scan to the hdd, but the network device doesnt show any folders, or scans, but they are in the doc server, i need to be able to retrieve them of the network, the 6004 is on the net work, and shared, but the scans dont show up
    please advise.. thanks you
    Re: mpc6004ex as a network device for scans
    what are the network/scan settings .. please post SMC report
    • luca72
      • Oct 2017
      • 1784
      you give us too little information, I'm not sure I understand, you mean that you don't see the folders on the display? do the scans work? what does wim's registry say?
      "I'll be back"
        • 37531
        Are you accessing through WIM?
        • copytrust
          • Feb 2010
          • 118
          i will try to guess....you didnt use the scan option, you used the document server option! and you want to access the documents now. is that right??
          • digicor
            • Jul 2008
            • 1159
            I used the doc server and can accsess the dox from the web monitor,
            i thought i had to map this a network drive to use it as a scan server(if you will) but not an option,its there in the mapping suggestions, but there is no further option to map
            i am sorry for the missing info.. im not a pro at using the machine as a scan networked option, i always set up email/smb/ftp...
            the client wanted to use the device as the scan server on his network...
            so if any help to explain what im missing how to do this thanks in advance
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              If this model works the same as previous ones, it requires a file format converter option, which has always been a physical board, although it may be an SD card on newer models.
              The files stored in the doc server are not PDFs, JPGs, etc, so they need to be converted to be in a usable format.
              I may be off base here, but I don’t think I am.
                • 37531
                I know that on previous models that you could access the first page of any file in the doc server through WIM by logging in as a user, not an administratorThe File Format Converter is needed to download entire documents. File Format Converter Type M19 EDP Code 417508.
                  • 37531
                  To my knowledge if there is a way to share the HDD of the C6004 it would requiring accessing at the OS level, which is some form of Unix/Xenix/Linux, through telnet. But I doubt it. The commands need to do so are most likely not available to telnet.
                  Documents can also be placed in the document server from computers by set the Job type for a print job to Document Server. You can also select which of up to 200 folders on the Document Server to place them in, each of which can be password protected. Be aware that the C6004 HDD should not be used for storing documents that are not backed up elsewhere. The entire content can be deleted from User Tools. In fact there is a setting that will automatically delete documents after a set number of days if it is not turned off. Also if at anytime you have to reformat the HDD, they are gone.
                  • rthonpm
                    • Aug 2007
                    • 2859
                    You'll need to explain to the customer that the 'Document Server' feature isn't a network server, it's dedicated storage on the machine for storing documents for print on demand. It's for things like safety checklists or fax cover sheets: documents that don't change and need to be printed frequently.
                    To truly scan to their network they will need a proper SMB setup: even an always-on PC with a shared folder will do the trick.
                    Sent from my BlackBerry using Tapatalk
                    • mikadonovan
                      • May 2008
                      • 2931
                      This should do it.
                      NEVER ASSUME ANYTHING
                      • sandmanmac
                        • 3981
                        Well Said!
                        I'd love to hear the rationale for why they would ever want the machine configured this way. Makes no sense at all to me
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          Originally posted by sandmanmac
                          Well Said!
                          I've been "isolated" to Ricoh for many years now, but I have heard that some other manufacturers provide that functionality.
                          Definitely a bad idea to have the capability; I can seen a ton of scenarios where really nasty things could happen.
                          • sandmanmac
                            • 3981
                            They definitely do.
                            While, I'm only dealing with Ricoh myself, I upgraded a customer about 8 months ago to a C3504, and was surprised to find out that's how they were scanning to their old machine that apparently wasn't compatible with Windows 10 (at least according to their previous tech)
                            I think the other machine was a Toshiba, but not sure.
                            They lived with it for a couple of years. They'd scan to the machine, then copy the file over to a server folder because their concern was with the machine's HDD dying.
                            Not exactly the most efficient method
                            • digicor
                              • Jul 2008
                              • 1159
                              The client had a previous machine that did this, this is why they were wanting it hat way
                              and old Toshiba Estudio8610 ....blah blah something, this is what set all this in motion
                              the old " well the other machine did it"....LOL
                              Im setting it SMB on there server, same thing,,,, just different... LOL
