SPC 252 sf Memory Overflow Error
  • Lagonda
    • Aug 2008
    • 1649
    [Error Code] SPC 252 sf Memory Overflow Error
    Please be gentle with me as it's been 18 months since I retired and I have forgotten so much (a lot of it deliberately!)
    The old faithful SPC 252 died so I upgraded to a SPC 252sf that fell off the back of a truck but it keeps telling me its got memory overflow when I try to print more than two pages of an automotive workshop manual.
    Tried PCL 5c and 6 drivers and speed and resolution setting but makes no difference. What have I forgotten as the grey cells start to die off one by one?
    Cheers, Phil.
    Re: SPC 252 sf Memory Overflow Error
    Cheers, Phil.
    hey Phil,
    does it have a DIMM module in it? did you reseat it?
    • Lagonda
      • Aug 2008
      • 1649
      Do they have one? I had a look at the boards behind the rear panel and couldn't see a socket for one.
        Ok well, try reseating all harnesses.
        Other than that I've played my hand.
        • Debs1964
          • Oct 2010
          • 1687
          Is it possible that, whoever used it previously, used locked prints and didn't print or delete them, so the memory is full
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • luca72
            • Oct 2017
            • 1711
            Cheers, Phil.
            try to make a nice sp801, from first to last, and possibly go over it with a firmware
              • 37059
              When you go to the FAX function screen does it show 100% memory available in the upper right hand corner? I have had machines that failed to clear fax memory after printing a fax.
              • Lagonda
                • Aug 2008
                • 1649
                How do I access SP 801?
                • Lagonda
                  • Aug 2008
                  • 1649
                  Errr.....no memory percentage display in the fax screen.
                  • Lagonda
                    • Aug 2008
                    • 1649
                    HI Debs, nice to know your still around.
                    Can you give me a hint, where do you find locked print?
                    • Debs1964
                      • Oct 2010
                      • 1687
                      Hi, I've recently come back on, I missed you being around
                      Here is the page from the user manual on deleting locked prints
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Found it! Panic over everybody, problem solved. Stopped trying to print from a NUC running Open Office and printed from the laptop with MS Office and all went well.
                        Thanks for your input everybody and nice to know I haven't been totally forgotten.
                        Now I'm going to wander off into the sunset again and hope you lot keep working hard keeping the world of commerce running and paying your tax that helps fund my retirement. 😋
                        Cheers, Phil
                        • tsbservice
                          Field tech
                          • 7942
                          Hey Phil good to see you around, keep calm and drive Mazda
