mpc6004ex only one impression
  • digicor
    • 1159
    Newly installed mpc6004 when they ask for 15 prints its only printing one print and thats it, its ready for the next job?
    and
    i have a mpc4504 double imaging with only 6k blk and 40k color? how can this be? installed 2 weeks ago now its doing this, any explanation?
    thanks
    Re: mpc6004ex only one impression
    and
    thanks
    what is the total counter?
    are they using strange media not defined properly?
    genuine OEM toner?
    • digicor
      • 1159
      oem toner on the 4504
      and on the 6004 its just plain paper
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        and
        thanks
        1st problem easy media mismatch error install correct driver turn on auto continue in printer setting.
        2nd problem be good to see samples probably rubbish toner and or paper type settings
        Regards Mark
          • 37532
          Sounds like they pressed the "Sample Copy" key and then waited too long to press continue.
          • digicor
            • 1159
            thanks yeah i think so too
            trying to save trip,
            1st issue solved , wrong drivers installed.... dumb it people
            second issue cant find reason for it....
            • digicor
              • 1159
              I had a c5502 do this to us,only in K not in color, i changed the PCU, Fuser, ITB....went away and came back after like two months, i ended up changing out the machine...
              is POWER a culprit? this c4504 replaced a c5502 that had NO ISSUES, so client is not happy,,,neither am i..
              • mikadonovan
                • May 2008
                • 2931
                I think there is a bulletin that covers the K development unit splotching toner right down the middle of the prints. I know that's not double imaging, but it's all I can think of at the moment.
                NEVER ASSUME ANYTHING
                • FrohnB
                  • Jul 2017
                  • 1919
                  Can't rule out a faulty (early failure) fusing sleeve.
                  Omertà
                  • digicor
                    • 1159
                    early part failure at like 70k? for a fuser sleeve thats supposed to go at least 150? probably the issue....
                    • digicor
                      • 1159
                      fusing sleeve part i have is D2424042 is there another part # ?
                      i cant seem to find this in my suppliers
                      • digicor
                        • 1159
                        found it as D2424041 not 42
                          • 37532
                          D2424041 is what is shown in the Product Support Guide for North America. Based on the Parts Catalog I have for the slower models the 42 might be the 220/240 volt model for most of the rest of the world.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            The sleeve assy is 400k if oem complete assy not just fit sleeve film on it own Ie compatible that could cause double image as well as rubbish toner
                            Regards Mark
                            • digicor
                              • 1159
                              its oem as far as i can tell, i ordered oem sleeve and lower roller always replace these together,
                              toner is oem, i just can see failure at 60k-70k impressions,,, but who knows..
