IMC3500 Duplex jam
  • GeorgeBest
    • Jul 2009
    • 525
    IMC3500 Duplex jam
    IMG_8193.jpgIMG_8193.jpgHi guys,
    Got this weird duplex jams on this IMC
    When doing a couple of duplex prints or copies, no problem.
    however, when a large job of duplex is printed it causes this jam around the 20th output of the print.(?!!)
    It stuck at the duplex turn and entering the heater, see picture.
    It jams every time around that point. (doing more then 20 jobs)
    changed the exit unit, fuser, duplex unit and even the fuser/exit/ drive unit.
    No results . .
    Machine has not reached the 5K yet . .
    There was once a SC622-11, rarely happened.
    Someone seen this before?
    Thanks in advance ,
    Gr George
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: IMC3500 Duplex jam
    Same problem with normal, good and new paper (not perforated) ?
    • anothertech
      • 1768
      What is the jam code?
      • GeorgeBest
        • Jul 2009
        • 525
        Jam code 019
        • GeorgeBest
          • Jul 2009
          • 525
          Same problem, from every cass.
          A4, A3, doesn't matter . . .
          • dalewb74
            • Feb 2018
            • 1151
            Originally posted by GeorgeBest
            [ATTACH=CONFIG]49139[/ATTACH][ATTACH=CONFIG]49139[/ATTACH]Hi guys,
            No results . .
            Thanks in advance ,
            Gr George
            in the service manual you found the SC code that you posted? 622-11 doesn't appear to point to any of the parts that you stated you have replaced.
            • GeorgeBest
              • Jul 2009
              • 525
              That's correct, but the SC622-11 was just indicated one time as I mentioned. Probably incidental
                • 37481
                Have you even looked in the service manual? I doubt it. Otherwise you wouldn't be calling it a Duplex jam. J019 is a fusing exit jam, that is to sat the lead edge of the paper made it past the rfusing entrance sensor but never made it to the fusing exit sensor. From the picture of the creased sheet of paper just below the bottom of the fusing unit I would say that you have toner caked on the fuser entrance guide plate from using cheap quality supplies. Either that or the guide is not adjusted correctly for the type and weight of paper used.
                • semi
                  • Sep 2008
                  • 193
                  Bridge unit/finisher fitted? Could have wrong style exit rollers fitted to exit unit,cleaning unit could be blocked
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    How long is this machine with that customer, working?
                    For i think it's a warranty matter!
                    • GeorgeBest
                      • Jul 2009
                      • 525
                      Dear Slim,
                      It jams only in duplex mode . . run a lot single sided, no problems
                      Are you spitting your manual for every fault, its more on experience . . .
                      again, only duplex . .
                      Nice day
                      • GeorgeBest
                        • Jul 2009
                        • 525
                        Comes with an internal finisher, but disabled it . .
                        • GeorgeBest
                          • Jul 2009
                          • 525
                          Yes, it is warranty . . . 2 guys from Ricoh came and worked for about 6 hours on it.
                          finally they discovered the cause, its the controll board. Ordered a new one and they are coming back next week.
                          • GeorgeBest
                            • Jul 2009
                            • 525
                            thnx for the replies
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Can't see that would be the controller board but if that's what they say. Also put the original right door but on as the one on there looks like it's done more then 5k
                              Regards Mark
