Pro C5100 - SC401-01
  • fatfingers73
    • Feb 2013
    • 219
    [Error Code] Pro C5100 - SC401-01
    Afternoon all,
    Having trouble with this code.
    Tried transfer power pack, toner supply motor, cleaned dustproof glass and tried complete PCDU from another machine.
    I'll get a couple of washed out prints before code returns.
    Any advice would be great
    Thanks.
  • GIUBOSS
    • 1433
    Re: Pro C5100 - SC401-01
    Originally posted by fatfingers73
    Afternoon all,
    Thanks.
    Genuine drum? Old developer? Did you clean the surface of the developer roller? Try cleaning the ID sensor and then running the manual process check.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Afternoon all,
      Thanks.
      You can't just swap over pcdus from other machines on production they need to be setup correctly
      Regards Mark
        • 37481
        Just a quick check of the service manual Replacement and Adjustment - Development Unit shows After you take this part out of the machine and put it back, or replace it with a new one, carry out SP3-040-001 to SP3-040-005 (DEMS: Execute).
        • anothertech
          • 1768
          Trying a complete PCDU from another machine was a good move and should have produced good output. The problem must be somewhere else.
            • 37481
            Only if he ran SP3-040-001 to SP3-040-005 (DEMS: Execute) after doing so.
