Ricoh Mp c2004 SC672-00
  • tibbs
    • Aug 2008
    • 223
    Any ideas as to solving Sc672, heading out to a customer in a few dats time with this issue.
    Regards.
    • 22808
    Re: Ricoh Mp c2004 SC672-00
    Regards.
    it's covered in the service manual
      • 35061
      Phil,
      About the link you posted.
      Malwarebytes Browser Guard blocked this website because it may contain pup activity.
      PUPs, or Potentially Unwanted Programs, are programs that may include advertising, toolbars, and pop-ups that are unrelated to the software you downloaded. PUPs often come bundled with other software that you installed.
        • 22808
        Phil,
        thanks but I got no notice of PUPs from my three checkers.. which one kicked yours ? my malwares didn't pick oy up
        • davel
          • Oct 2011
          • 1045
          It also has nothing to do with codes on copiers.
            • 35061
            Are you saying that you don't want to be warned about possible malicious websites?
            • anothertech
              • 1714
              First thing to do is to update all firmware, don't forget to update the smart operation panel too. Next, turn off Java if it's not being used. If still a problem, try replacing the hard drive and reseating memory dimms.
                • 35061
                The following is from a bulletin for the 03s but should still be applicable since the service manual for the 04s lists the USB connection as a possible cause.
                SUBJECT: SC CODE 672, 672-11 OR 672-12 OCCURS
                SYMPTOM:
                A Service Code SC672, SC672-11 or SC672-12 occurs.
                CAUSE:
                The Operation Panel communicates with a controller through USB cable and IPU. When the Operation Panel
                cannot communicate with a controller, the Operation Panel displays SC672 or SC672-11 or SC672-12.
                The MFP displays the Service Code constantly or intermittently during a print or copy job. Sometimes after
                rebooting the MFP code clears and appears after some time.
                These are following possibilities or causes:
                • [*=1]Failure of the USB communication path or Damaged USB connector ( Fig 1 USB harness Part Number D1495225)
                  [*=1]No response from controller
                  [*=1]Bad Memory DIMM or IPU
                  [*=1]Incorrect procedure followed during converting regular operation panel to smart operation panel or vice versa.
                Before spending money replacing anything, try disconnecting from both the controller and the panel and plugging back in.
                • tibbs
                  • Aug 2008
                  • 223
                  Thanks much to all of you who has responded and thrown in your suggestions and ideas, i will get back to you guys when get back from visiting the customer.
                  • luca72
                    • Oct 2017
                    • 1549
                    Regards.
                    it could be the usb cable behind the card, try to disconnect it and "press" it lightly with pliers, so as to make it a little harder to insert, while you're there, clean the contacts between the cards, and update the firmware
                    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
