SC142 Ricoh MPC3003 and 3353
    Re: SC142 Ricoh MPC3003 and 3353
    Originally posted by lukboruta
    iN 20+ YEQRS IN THE INDUSTRY I HAVE NEVER SHORTED OUT A BOARD BY LEAVING A GROUND WIRE DISSCONNETED.... do you think i dont check my work? Mistakes are common, dont judge me... i try my best.... every time...
    " Mistakes are common, dont judge me.."
    common for whom?
    " do you think i dont check my work? "
    frankly I don't know what to think about your technical skills.
    or your spelling skills for that matter!
    I'm outta here.
    • lukboruta
      • Nov 2014
      • 21
      Ok so you judged me.... now try to help me, i assume you dont make mistakes.
      • lukboruta
        • Nov 2014
        • 21
        [QUOTE=lukboruta;1777804]iN 20+ YEQRS IN THE INDUSTRY I HAVE NEVER SHORTED OUT A BOARD BY LEAVING A GROUND WIRE DISSCONNETED.... do you think i dont check my work? Mistakes are common, dont judge me... i try my best.... every time...[/QUOT]
        I see U are very self confident, but does it mean u dont make mistakes? really? so please, dont judge me, if you dont want to help me.... stop talking.... that forum has been create to help people and schare dvices, not judges.....
          • 37052
          #19
          Mistake are not common when you follow procedure step by step.
          Ok so you judged me.... now try to help me.
          Read my reply from about an hour ago.
          • lukboruta
            • Nov 2014
            • 21
            #20
            Sorry but i dont need such advices. I know my value.... so if you like to desscredit someone...stop doing that.
            Do you have any practical advices or no? I made mistake, i know... so stop talking about it.... its useless..........................
              • 37052
              #21
              Here, I will posted it again for you.
              Since the data from the scanner passes through the SIO it is most like the only thing damaged unless what the ground wire shorted was a signal coming from the board on the back of the lens. That board is where the white reference data is processed. That board is not field replaceable. In that case you may need lens holder assembly.
              Now go play games with someone else and do not bother replying to me. As soon as I submit this reply I will be placing you on my ignore list.
              • Babujoseph
                • 35
                #22
                Did fix the problem if not PM me
                • Zaxxon
                  • 608
                  #23
                  My mistake was reading this thread...
                  Please start you post with brand, model, problem.
                    Amen brother.
