Nozzle Clogging in GTP RI2000
  • en.
    • Jul 2014
    • 124
    DEAR SIR
    HAVE AGOOD DAY
    I have a problem with the RINTER DTG RI2000 printer, the printer was installed new two months ago, after a while, it was found that there was a cut line when working in the white print head, and there was a blockage in the print head ...A daily and weekly maintenance was made, but the problem was not resolved ... The cleaning fluid was requested, and the problem was not solved, so is there a program or process that must be done when applying the cleaning fluid
    best regards
    • 37508
    Re: Nozzle Clogging in GTP RI2000
    Sounds to me like automatic maintenance routines were not being carried properly. After 2 months a daily and weekly maintenance is not enough. By now you will have to replace the nozzle assembly. From the Owners Manual:
    ATTENTION! Auto maintenance will be not be perform if the following conditions occur. Failure to perform Auto maintenance can result in a clogged print head. These conditions need to be cleared ASAP so auto maintenance can be performed.
    Printer is powered off. (Always keep the printer powered on unless it has been flushed with cleaning fluid)
    Ink cartridge is missing or reading 0%
    Waste tank is full
    CR encoder error and other errors
    Any Service call message (see trouble shooting guide) - message bar at the top of the screen will be red
    Front cover is open
    The ink bay has been opened for maintenance
    If the auto maintenance is not being performed, then the print heads can be clogged.
    IF Auto maintenance is prevented from happening for any reason the following message will appear
    My guess is that the printer was turned off every night or at least every weekend without being flushed with cleaning fluid first.Cleaning fluid is to clear the tubes and nozzles before they clog, not after
      Waste tank is full
      Front cover is open
      Clogged ports are a common thing on ALL ink based life forms.
      Under usage is the contributing factor on ink based units... all across the brands.
        • 37508
        That is the reason for allowing auto maintenance to run as often as possible.
        Below is a list of maintenance procedures and frequency for those that are time based.
        Every 1 hour
        Automatic White ink circulation
        Every 3 hours
        Automatic White channel cleaning
        Every 12 hours
        Automatic All channel cleaning
        Alarm agitating white cartridge
        Every 3 days
        Alarm White jig clean, Alarm manual maintenance, clean white maintenance unit manually
        Every 10 days
        Alarm Color jig clean, Alarm manual maintenance. clean color maintenance unit
        Obviously the white ink cannot go long periods non usage, only hours not days. No wonder en. has so many red cards. He can't even train customers on what is in the Operator Manual. Either that or he is an end user who doesn't bother checking his Operator Manual. It took me all of 2 seconds to find it online.
        • en.
          • Jul 2014
          • 124
          Waste tank is full
          Front cover is open
          Sorry, it seems that I was not able to communicate the problem correctly.. The printer is new two months ago, it was sold... and it was not left without work for two months.. On the contrary, the customer performs daily and weekly maintenance..but the customer discovered a white cutout and a blockage in the head printing ..
          My question is: Can I open the print head and clean it without replacing
            • 37508
            Was or was not the printer turned off over night or on weekends.
            • en.
              • Jul 2014
              • 124
              and the solution is??
                from what Slim laid our for you if they turn it off it doesn't do the hourly CLEANING of the print head
                "Printer is powered off. (Always keep the printer powered on unless it has been flushed with cleaning fluid)"
                any ink based machines I have worked on ie Epson .. brother ... HP you can't disassemble the print head
                are you a trained tech on these units?
                do you have the manual?
                did you sell them the unit?
                if yes to all of the above you have failed your customer for not telling them how to properly maintain the unit.
                I never left the customer hanging by not going thru all the steps for properly maintaining the unit.
                Is the unit close to a window or an AC vent? that will cause the printhead to dry out faster (all covered in the service manual)
                you need to be proactive not reactive with ink based machines
                • luca72
                  • Oct 2017
                  • 1780
                  DEAR SIR
                  HAVE AGOOD DAY
                  best regards
                  hi, look, i don't know that model, but i can give you two tips about inkjet machines:
                  1) especially the professional ones, once the inert liquid has been freed and the ink passed, the customer must NEVER TURN OFF, because the machine occasionally starts a head cleaning routine by itself, insist on this, maybe do put a sign near the switch
                  2) you can try to clean it like this, with a clean rag and alcohol or chante claire, which dissolves the ink, the machine is not the same, but the concept yes...it generally works if not too clogged
                  Ricoh MPCW2201 Manual cleaning for unlock head clogged After lockdown - YouTube
                  "I'll be back"
