printer preferences from old machine to new machine
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    At this customer there was a mpc2800, and now a imc3000.
    Letterhead was/is in tray 3 (both with mpc2800 and imc3000)
    When older Word doc's wanted to be print (one from tray 1 & one from tray 3) with preference = tray 1, it is always printing from tray 3...
    Even when we select tray 1, that won't make a difference, it only print from tray 3.
    So, we copy paste the text and put it in a new Word doc, and that is ok, as long as we select "copy without all other settings" (or something like that).
    If we copy those "all other settings" with it, it is the same problem.
    We were obligated to use the same IP address (on the command of the IT'er) as the mpc2800, could that be the issue?
    Thanks in advance.
  • dave w
    • Jun 2015
    • 230
    Re: printer preferences from old machine to new machine
    I would check the word doc Page Setup
    Select Print = look under the Settings options and at the bottom another link = Page Setup - select the Paper tab and check the page setting.
    • Mark Bbb
      • Jun 2012
      • 1662
      In Word the setting under "options", "advanced", "print(settings)", "standardtray", says "use the printerpreferences"
      But still it will print from tray 3 instead of the tray we have selected at the preferences.
      So, we think it is a matter of the (same) IP address, because i have experienced before that this will give such bizar issues.
        • 37377
        Age old problem with Microsoft Word. Unless you tell it otherwise the printer settings are saved with the document.
        • mojorolla
          The Wolf
          • 2596
          The Word file itself has the tray setting in it. I use this scenario in my training classes to teach Printer Hierarchy...try this:
          In Word FILE > OPTIONS > ADVANCED > scroll down to the heading that says Print. Here you will find all your printing settings for the file itself. The settings you want is called Default tray.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            • Mark Bbb
              • Jun 2012
              • 1662
              In Word the setting under "options", "advanced", "print(settings)", "standardtray" = "use the printerpreferences"
              • luca72
                • Oct 2017
                • 1748
                I did not know this, interesting, thanks
                "I'll be back"
                • mojorolla
                  The Wolf
                  • 2596
                  Is the file protected or is it editable in Word ?
                  You mention an "older" version, what Word file type is it (doc or docx) ?
                  • JayPaul
                    • Oct 2012
                    • 305
                    Seen this a few times over the years. Usually when 1 person creates a document, saves it a certain way and sends it to someone else. Those settings are built into it but the new person can't see them so when it prints a wrong size or tray etc they blame the printer.
                    Workarounds have already been mentioned in here, depending where they get the document from originally I sometimes say can you ask that person to not set thsoe defaults before sending to you, if they have a known relationship.
                    Other times customer is happy to just copy and paste into a new document... this is also the best way to prove it is not the printers fault as well.
                    I think in Advanced - Printer Settings there is a dropdown box to select default tray or choose print driver settings on latest version of Word, maybe others?
                    Essentially several ways to get past it, usually what ever the customer finds most practical.
                    A bit like when chrome has a little print option tick box to ignore driver settings, so it tries printing its own way and machine starts beeping to say paper mismatch.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      File protected; i don't know that.
                      Older i mean created with the mpc2800 as default printer.
                      • rthonpm
                        • Aug 2007
                        • 2849
                        Sadly enough, this is still a thing with many applications...
                        For a long time, I had a team that used Crystal Reports, which would store the printer in the report settings. Every time they upgraded printers or had to go to a different office, they ad to create a new report with a new default printer to get everything to print correctly.
                        • mojorolla
                          The Wolf
                          • 2596
                          I feel your pain and have fought this battle a few times with Crystal Reports. Also with a piece of software called Chiro, which is used in chiropractic offices which loves to confuse the mfp.
                            • 37377
                            Did you change the tray selection in page format?
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Slim, good thought, i will inform customer to try this, because now is "use printersettings" selected.
                              Just tried, no good, it will still print from tray 3
