Ricoh Aficio 1035 SC542 Error code
  • Kosta25
    • Jun 2021
    • 10
    I have a Ricoh 1035 with a brocken fuser heater lamp.
    I see on China Market 250w 400w and 640w lamps.
    How can i determine witch Power i need for my copy Machine?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Aficio 1035 SC542 Error code
    It should say on the plastic part of the lamp what wattage it is. What part of the planet are you on and what is your local mains voltage?
    Hit it.
    • Kosta25
      • Jun 2021
      • 10
        • 37533
        If you are smart you will avoid that "China Market" like COVID. Two things, none of the power ratings match those used in the 1035 and you run the risk of your credit information being stolen.
        There are 2 lamps in the 1035 fusing unit. which one is broken?
        AX43 0073 Heater - 230V 550W 335mm end lamp
        AX44 0199 Heater - 230V 650W 215mm center lamp
        The sizes of the holes in one of the lamp holders match the sizes of the ends of the 650 W lamp (red) and 550 W lamp (brown).
        Considering that the 1035 was introduced 20 years ago, parts are most likely no longer available. Unless you can find a a functioning used 1035, you now have a boat anchor.
        • GIUBOSS
          • 1436
          i found this:
          AX43 0064 Heater - 230V 550W 335mm
          AX44 0129 Heater - 230V 650W 215mm
          maybe they are old codes
          • Kosta25
            • Jun 2021
            • 10
            Originally posted by GIUBOSS
            i found this:
            AX43 0064 - This lamp is broken. Hard to find...
            • GIUBOSS
              • 1436
              [QUOTE=Kosta25;1817472][COLOR=#333333]AX43 0064 - This lamp is broken. Hard to find...
              I could look for it among my old things
                • 37533
                You might be able to use the lamp for the 3035. Four year later introduction date so parts might still be available. Wattage is higher everything else is still the same. AX44 0174 Heater:230V:650W:335mm
