Ricoh C2503 - Abnormal Horizontal Lines
  • printertnc
    • Jun 2015
    • 68
    Good evening
    A customer's printer exhibits this anomaly when printing some color pages
    Could it be the PCDU?, should I change them?
    If I run the color test, the one with the colored stripes, this anomaly is less evident.
    Suggestions are accepted
    Thank you
  • emiliorsg
    • Jul 2018
    • 141
    It seems to me that the cyan development unit needs to be changed.
    • luca72
      • Oct 2017
      • 1779
      try to clean optic and laser scanner glass, and check pm counter to find end life parts
      "I'll be back"
        • 37491
        Could be toner clumps or paper lint/dust obstructing the doctor blade in the DVU. Or dirty laser shield glass.
        • Scraft
          • May 2024
          • 2
          do a single color conversion from there you can direct pin point to which color.
          1. First clean the laser shield.
          2. Will be harden toner in your development unit. dare to challenge by opening the left and right screws of the development unit facing the magnetic roller. This will loosen the doctor blade. Next remove the cover for the development unit and pour out the developer. Seave/Filter the developer to remove any harden toners. pour back to the development unit once done.
          3. Use a gauge for the gap of the doctor blade adjustment
