Faint Black on Ricoh MPC2003 color pattern, copy and printout.
Re: Faint Black on Ricoh MPC2003 color pattern, copy and printout.
Originally posted by Pixtech Frameworks
Still the same shit.
Try a large format sky shot (or better force full black via SP mode/testpattern) and interrupt it:
Does the toner density look solid on the drum surface + transfer belt (hard to see unfortunately)?
How much toner is left on the transfer belt after the paper transfer passage?
Did you try a different & freshly-unsealed stack of paper?
What do I do???
with your fingers, turn the gear of the black development group a few turns, back and forth a dozen times, to clean a doctor blade, and try, then try to reverse the pcu of black (pcu only), with that of yellow, and see what happens, if you don't solve.. at this point you just have to do as I do, go to the customer with (ITB unit, pcu, dev unit, and possibly another power pack, all of another machine
