Faint Black on Ricoh MPC2003 color pattern, copy and printout.
  • Pixtech Frameworks
    • May 2020
    • 241
    Hi All,
    I am stuck with this customer Ricoh MPC2003 that has a faint black on color pattern and generally, print and copy. I've installed a new OEM developer, OEM toner, clean optics, cleaned laser shield, check toner hopper if the toner augler is broken, and have tried virtually all what I know, but to no available. Any solution will be appreciated or if there's any adjustment to do on system sp.
  • copyaction
    • Oct 2007
    • 991
    Re: Faint Black on Ricoh MPC2003 color pattern, copy and printout.
    Originally posted by Pixtech Frameworks
    Hi All,
    Have you replaced the PCU?
    In addition this procedure has been mentioned before:
    Check value Sp 3201-001 if it is 3.5v or higher then do the following
    Sp 3201-001 set value to 4%. (mine was at 9% to start)
    after change make 1 copy or print internal test pattern this applies the value of the change you just made.
    Execute SP 3050-003 three times (Toner add for black i believe it was.)
    Check the value of SP 3200-001
    if the value is 4 or higher your done if it is less then 4 repeat the above steps until it is 4 or higher.
    This is bottom half of TSB #6 on the 2003/2503, the first part of the tsb is for light image only on lead or trail edge, this part i gave you resolves the whole page being light.
      • May 2020
      • 241
      Ok copyaction. I'll do all what you write and get back asap.
      • CopyBats
        • Aug 2011
        • 147
        Did you connect the ground plate cover for the Drum correctly? When you installed new developer did you indicate that in the machine by going into SP 3701 and manually setting black developer?
        Once you indicate that it is manually set, turn off the machine from the main power switch and then turn it back on.
        Hi All,
        If it works, don't touch it.
          • 37652
          All colors on you color gray scale you posted are weak. Normally caused by a dirty ID sensor, dirty optics or both. Clean the ID sensor assembly and the area around it. Completely clean all dust, toner residue and filming from all scanner components. There is a possibility that white reference calibration when power is turned back will correct most of your problem. To optimize quality run Auto Color Calibration in User Tools. Do copy first as that will adjust the scanning. At one time there was an information letter put out that recommended running ACC anytime firmware was updated.
          • Polarbear
            • Feb 2012
            • 1070
            Hi All,
            Have you checked the pipe between the hopper and the dev unit? It is a rectangular vertical piece of plastic, that connects the toner hopper to the dev unit. If this is blocked, the toner will not get to the dev unit and copies will be feint.
            Press the GREEN button!!
              • May 2020
              • 241
              Auto Calibration had been done several times, but to no avail.
              • Gift
                • Mar 2011
                • 2459
                I think it's not just black looking faint. Did you check a different paper, perhaps it's too moisty or dry or rough on the surface? Also keep the ID sensors clean as stated before.
                Otherwise you can perform force toner supply via SP to "revive" old DV units and initialize the devs again but I wouldn't recommend that if the result looks faint
                with a brand new DV unit.
                • skynetto
                  • Sep 2012
                  • 257
                  Whats the status of the trasfer/separation unit?
                  Check if it is properly grounded.
                  Check if the transfer roller is properly touching the ITB housing at sides. if one or both of housing is broken the roller falls a bit down giving you faint prints.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Hi All,
                    What pcu pm life also did you replace complete dev assy {new} or was it used or just developer
                    Regards Mark
                      • 37652
                      But were the optics properly cleaned first.
                      • FrohnB
                        • Jul 2017
                        • 1919
                        What was the PM count for the developer? Developer and PCU have the same expected yield of 60k, and we nearly always replace both at the same time.
                        If you do/ did replace the PCU, you have to input the correction coefficient (there's a label on the PCU that gives you this info) into SP 2-005-235 (K), and set SP3-701-002 (Manual New unit set) to "1" before turning the machine off and replacing the part. Upon restarting the automatic initialization of those settings takes place.
                        The same goes for when you replaced developer. Set SP 3-701-003 to "1", turn machine off, replace part, turn back on.
                        I don't believe you can get just developer powder for this series, so if you replaced the development unit, that entails "splitting" the PCDU unit. I've seen where the contact plate/ cover on the back of the unit doesn't get put back on, and you get problems like the ones you're having.
                        Otherwise, you're looking at maybe a bad black transfer roller in the ITB unit.
                        My money is on development or drum unit though.
                        Omertà
                        • luca72
                          • Oct 2017
                          • 1792
                          Hi All,
                          didn't you forget to reassemble the back cover of the pcdu?
                          in any case... clean ID sensors, and run the sp process control routine (all) via sp process.
                          p.s. don't trust too much of that sp printer test, it could be the bugged firmware and print it bad anyway, even with the machine in perfect state, its happened to me, and someone here on the forum a long time ago.
                          "I'll be back"
                            • May 2020
                            • 241
                            I reassemble the pcdu back cover, still no luck. Am suspecting the firmware, probably upgrade is needed.
                              • May 2020
                              • 241
                              This didn't work either, still faint as before.
