I use USB memory plugged into the printer but it doesn't detect any pdf files. I plug it into another printer of the same type and it still works. Can someone help me solve it?. Machine name Ricoh C6004.
Does not recognize PDF files in USB
Tags: None
You may need an SD Card with Adobe PDF.
Although the Cxx04 Series should have a generic emulator, if I remember correctly. Have you updated the firmware?"ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.๐ 1 -
As for firmware updates, I haven't tried it yet because my machine is used at an assembly factory, so all the computer networks here are internal and there is no internet connection... but I will try my best. somehowComment
We can be contacted at www.printerfirmware.co.uk
โComment
Can you web browse into the 2 devices? if so, you can compare the firmwares that are running on each device.
Does the device not reading the PDF files, detect the USB stick in the first place? Im assuming your going to Printer app, then Memory Storage Device?๐ 1Comment
