Ricoh IM C3500 Tray 1 Jamming
  • copier tech
    • 8121
    #16
    Originally posted by MPrint
    sandmanmac - Yes it has a finisher. Why would it only happen with tray 1 and not the bypass tray, using the same paper and settings?
    What about tray 2 does that feed OK ?
    • MPrint
      • May 2024
      • 9
      #17
      After further trial it seems that the paper feed error only occurs when the paper is put in the tray as long edge first. If I turn the paper to short edge first, which you can obviously do in the bypass and tray 2, it feeds correctly. Is there a setting I am unaware of or is this a potential repair issue? Thanks!
