LD540c Put new toner in and it says toner empty replace toner
  • techandtrader
    • Jun 2016
    • 335
    Just put in a new Genuine OEM Yellow toner and the machine is reporting that its empty and to install the toner.
    Not very familiar with this machine. What can we check or do? LD540C
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • TRJS
    • Mar 2018
    • 16
    Re: LD540c Put new toner in and it says toner empty replace toner
    Probably toner pump
      • 37575
      Let me count the ways:
      1. Bad toner pump or transport tube, replace as a set
      2. Bad RFID chip on toner bottle
      3. Bad RFID board that reads the RFID chip
      4. Clogged toner nozzle at the back of the toner bottle tray
      5. Bad toner end sensor
      FYI Ricoh model is Aficio MP C4000.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Replace toner pump
        Regards Mark
        • luca72
          • Oct 2017
          • 1791
          toner pump, or developer unit broken internal
          check the enter hole of the the developer unit, if its empty=toner pump, if very full=developer unit broken
          "I'll be back"
          • dalewb74
            • Feb 2018
            • 1167
            i had ricoh eco toner. on the box it said it fit that model. (this was the black). it fit fine, but said replace the empty toner. lucky enough right below where you insert the toner was a sticker telling the correct toner. after following the sticker it worked fine. simple check before you start replacing parts.
