MP C407 print by phone user not allowed
  • digicor
    • Jul 2008
    • 1159
    i have set these up before, no problems, scan QR code and they are on there way
    not this time
    the phone says cannot connect guest user not allowed? or something similar
    even when i put in the Ip address it still cant connect
    wifi same thing
    and i can seem to touch the phone to the screen anywhere either when it asks it still no connection
    wifi is configured
    im on there internal wireless system...
    is there a set up feature i can turn off security wise? to allow all users?
    i scanned through the manual ran through some things , logged in with 806182## c...
    any help with this would be most appreciated
    thanks in advance
    • 37532
    Re: MP C407 print by phone user not allowed
    Sounds like the owner of the C407 has set security to only allow approved individuals to access the machine. If they won't let you log in to their WiFi, your screwed.
    • digicor
      • Jul 2008
      • 1159
      i can log into the clients WiFi,, is there a deeper security setting on the machine? i can change the security settings in the web access, it didnt make a difference, Im thinking its in there security setting on there WiFi or internet access points, im checking today with there IT,
      we installed the machine yesterday, got it off lease, so there's that. the previous owners may have some kinda lock on it.I can turn the WiFi on and off, it has a certificate...just drawing at straws here...
      thanks for the insight ,
      • copier tech
        • 8174
        Sounds like you have user authentication/user codes enabled. Especially if the machine has just come back off lease.
        We have a C407 in the office & use the Ricoh connector app without any issues it works best printing via IP not using the QR or NFC option.
        • digicor
          • Jul 2008
          • 1159
          i just returned from the client
          i updated FW, ran a new cat 6 cable , changed the security setting to level 0
          one phone scanned the Qr code and worked, the other i had to manually load the ip address into it
          but as of now its working
          the security level is usually on 2 and i have no issues
          i never have had to set it at level 0 but its working and thats all that matters
          Thanks for the ideas
            • 37532
            Sounds like the previous owner was either the US Government or a federally regulated financial institute. Most likely had custom security settings. Unless you know how to modify custom settings, Level 0 is the only work around.
            • digicor
              • Jul 2008
              • 1159
              correct you are the security level was on custom...
                • 37532
                Originally posted by Lions86
                These machines have AIRPRINT feature. You can print from phones without the need for any application, provided that you connect to the same wifi.
                Not if "Custom" security is set to block Airprint.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Thats just for apple
                  Regards Mark
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    i have set up a mpc2800 successfully with airprint on windows 10.
