Ricoh C2050 - Problem with YELLOW
  • orientalsniper
    • Aug 2019
    • 8
    Hello, before I open up the printer, is this an easy problem like the yellow dum?
    The page should be full yellow. Ignore the middle vertical line, that's a scanner dust. There's also yellow stain at the top where there should be no yellow.
    • 37524
    IMHO you need a new PCU for the Yellow. When you pull the unit you might find the the photo-conductive coating is completely worn off where the yellow band is down the one side. The other color s will most likely need to be replaced soon. You are aware that dinosaur was introduced in December 2008 and replaced by the MP C2051 in February 2011.
    • orientalsniper
      • Aug 2019
      • 8
      Thanks for the input, I do know it's a dinosaur LOL, I just can't afford to buy a new one, I'll be happy if it can last me another year.
      • copier tech
        • 8167
        Try swapping the yellow PCU with another colour, that way you can rule in / out the drum being the issue.
