IMC300 SC271-03
  • Bug catcher
    • Jul 2021
    • 2
    IMC300 SC271-03
    Any info on IMC300 sc271-03
  • luca72
    • Oct 2017
    • 1778
    It's not in my manual, did you read or write correctly the sc code?
    "I'll be back"
      • 37490
      SC 271 could have to do with Skew or mirror control based on Goose's Guide for older models
      • Bug catcher
        • Jul 2021
        • 2
        Sorry, my mistake ! I was assisting a fellow tech. The SC code was SC272-03. Magenta laser drive command. Thanks for the responds from both of you. The solution was the BICU. Customer had forced the wrong magenta toner cartridge and was not detecting toner full. Tech could not remove bottle so force was used and broke the toner hopper cartridge in back. After tech replaced it, the SC code appeared. Problem solved . Something got scrambled in BICU board.
