Ricoh IM7000 Finisher SR4150 Jam
  • Thomas Schlender
    • Jun 2024
    • 8
    Hello everyone,
    I have the following problem with a Ricoh IM7000 with an SR4150.
    I only get a paper jam sporadically (J171) when double-sided and hole punching are selected at the same time.
    The paper then simply remains unpunched behind the hole punch unit!
    Hole punching for single-sided documents and only duplex copies work perfectly.
    As soon as both are selected, I get a paper jam at J171.
    I have replaced the following, but unfortunately without success:
    PUNCH UNIT:EU:CHANGE:ASS'Y - D3FP7516
    PCB:PUNCH:CONTROL - D3FN5240
    PCB:MAIN CONTROL:L:ASS'Y - D3GD5150
    DC MOTOR:10WIA42:BRUSHLESS - D6885620
    DC STEPPER MOTOR:MM42:L30 - D7067190
    PHOTO REFLECTION SENSOR:EXIT- GW010007
    PHOTOINTERRUPTOR:LG2A24RL1G - GW020026
    FW is of course new from the machine and the finisher, other paper has already been tried.
    I don't know if I'm in the right place here, I'm a Ricoh technician myself and Japan hasn't found a solution yet either!
    • 37556
    Might be a problem with the punch unit
    • Thomas Schlender
      • Jun 2024
      • 8
      No, as we have already mentioned, this is also completely new!
      • dalewb74
        • Feb 2018
        • 1162
        i think you need to download the service manual. it gives the fix for the problem you are having. rev 5/1/24
        • Thomas Schlender
          • Jun 2024
          • 8
          I'm a Ricoh technician for over 20 years and we have all the service manuals ready! But in this case the service manual is no help and as I said, you can see from my list what has been replaced, that is more than what the service manual suggests and what has it achieved? Nothing!
          • Thomas Schlender
            • Jun 2024
            • 8
            what is rev 5/1/24?
            • mfrigault
              • Feb 2017
              • 18
              Taken from IM7000 Service Manual:
              Cause -- JAM171 occurs because the bracket connecting the finisher to the main machine was displaced to the
              side-to-side registration during SR4150/SR4160 installation.
              Solution -- Adjust the connecting bracket between the main unit and SR4150/SR4160.
              For the adjustment procedure, refer to Skew and Side-to-Side Registration
              • dalewb74
                • Feb 2018
                • 1162
                revision 5/1/24 is the latest updated copy of the service manual. and it addresses the exact problem that you are having.
                • Thomas Schlender
                  • Jun 2024
                  • 8
                  Actually, this adaptation does not yet exist in German! I'll probably try that out! Thanks for the hint.
                    • 37556
