What is the cross for a LD255?
  • tinfox
    • 317
    What is the cross for a Lanier LD255?
    I can't find the exact Ricoh model. (very odd)
    TIA
  • DRichard
    • May 2008
    • 482
    MP5500
    "Enjoy every sandwich."
    -- Warren Zevon
    • tinfox
      • 317
      Great thanks!
      One more question. ;-) Is it a good machine?
      • Jomama46
        • 2900
        Dan, Dan, Dan. It is a good machine, especially if you rank a 1224 as a bad machine.
        sigpic
        A+; Network +; PDI+
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          I concur, good machine.
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            In that range, the best. hehe
            • TonerMunkeh
              Professional Moron
              • 3865
              Corker of a machine. Replace the dev when it's due, the reg mylars at 1 million and don't use aftermarket toner. All good things for a Martini.
              Hit it.
              • DRichard
                • May 2008
                • 482
                IMHO a FINE machine! So, of course Ricoh will replace it with another "improved" model.
                -- Warren Zevon
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  if plain copier... i'll go for martini c1... functionality wise like connectivity and others... ofcourse martini c3.5
                  fix the customer first then fix the machine... its simple and makes life more easy.
                  • Ollie1981
                    Toner Monkey
                    • Mar 2008
                    • 417
                    The MP4000/5000 has already pipped the 1224c as the worst Ricoh machine in my opinion. But then again I wasn't working on them during the whole faulty developer unit gear saga.
                    Hopefully it'll just be teething troubles with a new machine and the new toner blend will finally sort it out, but at the moment with several major account customers in my locality that have use these abominations at mid-high volume and having to carry at least ten bags of developer and a modified developer unit at all times on the car to keep them reasonably happy I wish I could take a sledgehammer to each and every one.
                    And yep, the MP5500 is a fine machine. Most of the "faults" I attend on these are purely down to user stupidity, the rest are usually a PM part over life.
                    • rthonpm
                      • Aug 2007
                      • 2860
                      PM at around 300,000 clicks and this machine will purr right along. I wish I could get a couple of my customers with the Evil MP 4000 to start running more pages so I could get them the chance to upgrade to a 6000...
                      • Shadow1
                        • Sep 2008
                        • 1642
                        Exact opposite of a 1224 or MP4000 - have several in a print shop (as well as the previous generations) They can take a beating and beg for more. Only weak spot - if they aren't run hard enough you get flat spots on the pressure roller so the machine thumps or growls when you make a copy and will eventually break the hot roller drive gear if not replaced.
                        The harder they are run the better - PM cycles in a print shop are a only a suggestion... they stretch
                        73 DE W5SSJ
