Used MP4055 with Equitrac - how to remove it?
  • Dougtech
    • Apr 2011
    • 113
    Got a MP4055 in but it has Equitrac. Loads to "unable to find server" with login button greyed out.
    Doesn't display IP address to try to access WIM. Can only access SOP (reset ******## C) but can't remove extended features from there.
    Anyone have any clue how to reset machine/get rid of Equitrac?
  • dalewb74
    • Feb 2018
    • 1153
    you really shouldn't post access codes to the public.
      • 37495
      Have you tried using the Ricoh Smart Device Connector to access WIM?
      • Dougtech
        • Apr 2011
        • 113
        Noted
        • Dougtech
          • Apr 2011
          • 113
          I have not. Would it work through USB as I don't know the machine's IP to even get on the same network scheme?
            • 37495
            No it connects directly to the Android OS of the SOP using either NFC or Blue tooth and gets the WiFi address as well as allows direct connection to WIM
            • Dougtech
              • Apr 2011
              • 113
              Thanks. Hopefully those functions are active, will give it a try on Monday and give an update.
              • Dougtech
                • Apr 2011
                • 113
                Nothing would work, but after hours of messing with it I got it
                At first thought causing an error would let me into service so i unplugged the fuser - no luck.
                After messing around a while a certain combo let me get into service mode - disconnected hard drive and removed fuser unit - now i could enter service and go through the Sims to remove the equitrac. reboot and remove through extended features. Reboot and now it's a working machine.
                Just wanted to let you all know.
                thanks for all the help
                  • 37495
                  Usually if an error code at startup is preventing you from entering the Service Program, instead of disconnecting everything just power ON with the doors open. This should prevent the engine from starting and allow you to enter service mode. After you are in service mode you will need to close the doors.
