Ricoh pro c5200 error code sc689-00
  • M.wagih
    • Mar 2024
    • 19
    [Error Code] Ricoh pro c5200 error code sc689-00
    How to fix this error for ricoh pro c5200 sc689-00
    • 37048
    How fucking many times are you post the same question. First you grave then you post at least 3 times!!! Not the way to make friends and get answers.
    • M.wagih
      • Mar 2024
      • 19
      Despite your insulting me, I will appreciate and respect you, and I will respond to you with all respect and appreciation. Firstly, what made me publish it a lot is because no one has solved this problem yet, and I work as a maintenance engineer and I have a client who is more suspended.
      • M.wagih
        • Mar 2024
        • 19
        This is my job and I want to work hard at it, and I also have to solve the problem for the customer, so I ask you if you can help, then do it, and if not, say good or remain silent, and thank you very much.
        • Miri
          • Jul 2024
          • 6
          IH Inverter Communication Error
          IH inverter not responding to request IH inverter communication error (ASAP IV compliant) IH inverter response information unavailable Harness broken IH inverter defective
          IOB defective
            • 37048
            First only us old fart retirees are on here all the time. It may take some time for those with current service information to login.
            Second your grave robbing most likely pissed off the better techs who might have answered you otherwise.
              • 8120
              Also check no paper is trapped behind the fuser draw.
              • M.wagih
                • Mar 2024
                • 19
                IOB defective
                Iob
                Do you have a picture of this if possible?
                • M.wagih
                  • Mar 2024
                  • 19
                  IOB Where is it located in the machine please, and thank you very much for your help
                    • 37048
                    Iob
                    I take it that you do not have a service. If so, get one.
                    • M.wagih
                      • Mar 2024
                      • 19
                      I changed the heater and the same problem still exists. I also changed this electrical board as it is in the pictures and also nothing changed.
                      • dalewb74
                        • Feb 2018
                        • 1125
                        with this being a production copier. i very strongly recommend you get a trained ricoh tech to fix this for you. and the fact that you don't have the service manual. im not trying to knock your abilities, but if done incorrectly, you could brick a very expensive copier.
                        • M.wagih
                          • Mar 2024
                          • 19
                          Thanks ?
