Whining noise IMC3000
  • Johan508
    • Jul 2024
    • 3
    Hello,
    We have a customer whos IMC3000 is whining/squeaking periodically when printing out. I located the problem when I did a motor check sp5804.
    It is the transfer drum motor K which is causing the problem. Can I solve this issue with WD40 or changing some small parts instead of swapping out the whole drum?
    The counter is only at around 40k.
  • tonerhead
    • Sep 2009
    • 582
    If it is only 40k, trim and reverse the lube bar, otherwise replace the lube bar in the black drum unit.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
      • 37059
      IMHO WD40 will cause more problems than it will fix. The WD stands for Water Displacement not machine lubricant.
        • 8121
        Strip the black PDU down it is usually the metal lube bar roller bushings or charge roller that cause the squeak, & yes a tint drop of oil does the trick.
