complete swap of mpc3501 pcdu into a mpc3502
  • fshead
    • 2378
    so
    I have a bunch of low meter mpc3501 PCDU that i pulled out from tradeins over the
    years ,wrapped them in lot of paper and store them in a dark place.
    I needed to swap out 4 drums on a mpc3502 and clipped the metal piece near the rear and
    inserted drum to get the drum error message.
    I decided to pull the td sensor and harness and swap it too.
    That was the ticket and now machines runs well.
    So the 01 dev units will work on the 02 series and the printer series too.
  • copier tech
    • 8220
    Re: complete swap of mpc3501 pcdu into a mpc3502
    Originally posted by fshead
    so
    This has been known for years.
    The xx01 PCU are cheaper than the xx02 so we have all been modifying & fitting these.
      • 37628
      You could try swapping 2 leads on the connector from the development unit to the drum unit. See attached
      B2C_Drum_Cheat_Sheet_v2[1].pdf
      • anothertech
        • 1771
        [ATTACH]49999[/ATTACH]
        Yeah, that's the way I've always done it, very easy.
          • 37628
          I can't remember who it was that first posted that but I saved it encase someone else needed it.
          • sandmanmac
            • 3990
            I've had it saved for ages myself....The first draft was posted by Lagonda way back in 2012
            Ricoh MPc4502 PCU
            Where the hell has the time gone!?
              • 37628
              Ricoh MPc4502 PCU
              And he has retired to spend more time with Mrs Lagonda.
              • fshead
                • 2378
                thanks.
                i did not sell many 02s so i might see one every year or so.
                And 01s are pretty much finished with maybe 304 still running.
                I remember seeing the wire trick but thought that was for changing K drums to color.
                Its been a while but thanks to all.
                • anothertech
                  • 1771
                  thanks.
                  Yes, now that you said that, I remember that I was doing the wire swap to change black drum to color drum.
