Aficio MP 5001 issues
  • Walter Chavez
    • Oct 2007
    • 14
    [CQ] Aficio MP 5001 issues
    Replaced fuser and need to reset web roll count or fuser count, also need to adjust background density, getting dirty copies
    • 37553
    Re: Aficio MP 5001 issues
    Resetting the counter is covered in the service manual. If you do not have one there is a forum for requesting one.
    As for the dirty copies it is most likely contaminated developer. If you have been using after market toner, it is most likely the cause. You need to clean out all toner residue from the PCDU and install new Ricoh toner, drum, developer, cleaning blade, charge roller and charge cleaning roller. Worse case you may need to replace the Development Unit.
    • 8T2
      • Aug 2015
      • 257
      Would like to add clean mag roller and replace Dev unit filters if rebuilding. Otherwise it will turn into a dirty pig of a machine. Also check the cleaning web flag, it may be broken if it's still coming up with message after fitting new web
      Sent from my WAS-LX1 using Tapatalk
      • Zeldaman
        • Mar 2011
        • 946
        • sandmanmac
          • 3983
          Haha.......aint that the truth!!
            • 37553
            Or on the wrong side of the web material.
            • Walter Chavez
              • Oct 2007
              • 14
              Got unit working, thank you all for the advice
