MP 4054 "Please Wait"
  • laser801
    • May 2014
    • 151
    Hello People, I have this P. I. T. A. !! 4054 Has an issue with a "please wait" not going away... I tried new H.D.,s and sent out Control Board to Hytec for repair too... They replaced NVRam, and sent it back... Guess what?????? PLEASE WAIT !!! Oh ...Not you! It still says it... Any suggestions??? Also put another Fuser unit in... Any help would be appreciated, Laser801..... Let me add, I have 2 machines doing the same thing and both were affected by a power outage due to a storm.
  • Polarbear
    • Feb 2012
    • 1070
    Re: MP 4054 "Please Wait"
    Hi
    Have you tried other ram modules?
    Also if it has a fax board on remove it
    Get it as close to basic as possible for testing.
    Have you tried booting it without the hdd?
    Sent from my SM-N770F using Tapatalk
    Press the GREEN button!!
    • laser801
      • May 2014
      • 151
      Originally posted by Polarbear
      Hi
      Yes! I unplugged HD and also Fax... The Red error light also comes on but I cant get into service mode or do anything...
      • laser801
        • May 2014
        • 151
        Hi
        Both NVRAMS are new...
        • FrohnB
          • Jul 2017
          • 1919
          Could be the BICU.
          If you know the controller is good (Hytec "tested/repaired", and the HDD didn't solve it, and removing the fax module didn't work, then you can bet that it's either the IPU or the BICU.
          As stated above, it could also be a Memory DIMM, but I'm leaning towards one of the other boards I mentioned.
          Hate power outages/ surges. Had storms a couple weeks ago that wreaked all kinds of Havoc on some of our Ricoh machines, but came across two different HP's that got a surge, and melted the fuser rollers together, direct hit to the Power Supply! Even melted the Power strip that the printer was plugged in to!
          Omertà
            • 37489
            Have you tried accessing WIM to see if there is a service code?
            • laser801
              • May 2014
              • 151
              Thanks for your Reply... We have already put other units in their place... I have a gut feeling its the BICU ... Getting a high mileage low cost unit in early next week , which we'll have to work with. Those repairs on the control boards were almost a G ... I can get this other unit in for less than 5 Hun... Thanks again, Enjoy the weekend
              • Dan G
                • Nov 2014
                • 56
                seen similar issue and new Op Panel was resolve? expensive though
                • Zaxxon
                  • 608
                  Please start you post with brand, model, problem.
