CL7000 Alignment
Re: CL7000 Alignment
Reality is that if I get to that much volume I'll be printing on off-set so I highly doubt I'll ever get close to that number before this machine is retired.Comment
I found this site that has a searchable database of printer codes that is very helpful:
Error Codes > Ricoh > CL7000 > Code SC 285Comment
The CL7000 was introduced over 18 years ago. It has long ago gone beyond the guaranteed support and parts availability dates. Time to replace the dinosaur.Comment
All of that information can be found in the service manual. Until you fix the SC 385 you are not going too have any luck. How did you "Clean the ID sensor?" You may need to replace the ID sensor assembly, if you can find a new one. The correct way to clean any ID sensor assembly is with a soft lint free cotton cloth slightly dampened with water only. Cotton does not cause static which can damage the LEDs and LDDs or will attract toner and dust which reduce the function of the sensors. Windex and multi surface cleaners will leave a film. Chemical solvents including alcohol will damage the surface of the sensors.
How do I get at the ID sensor assembly?
All I've been able to do is get at it from the front by removing the transfer unit and sliding the protective cover aside.
From what I can tell there is a connector at the ID sensor point and it is far more common for a bad connection, especially over time, than a failed IC. Especially multiple ICs failing at the same time. That speaks more to a failed connector in my experience.
If I was to replace the ID sensor assembly how would I go at it? From the fusing unit side?
The printer will be replaced in it's own time. There are still lots of parts available and they're cheaper than they were because they are now "salvage."
I've been in tech since 1980 and have watched "the latest and greatest" replace the "dinosaurs of old" so many times it's beyond boring. Why is something that works perfectly fine today no longer viable tomorrow just because somebody came out with something newer and stopped "supporting" the old? It's called "designed obsolescence" and has nothing to do with anything other than to keep profits rolling. It's also causing major social issues with all the needless waste.
My car is over 35 years old and still looks and drives like new. Like this printer, it was a popular model and there are still lots of parts around to keep it going. I'll keep it as long as it makes sense, and currently it makes more sense to spend a few bucks to keep the old running than thousands for a new one that will cost more to operate because the "support" is current and prices at a premium.Comment
Thanks. I appreciate your responses and help.
I take it that you do not have a service manual because ID sensor replacement is in the service manual. There is a forum for requesting one. https://www.copytechnet.com/forums/s...nual-requests/
There is a protective film, as one would expect, over the actual sensors, so applying anything other than water would cause a film to build up that can effect optics but not effect the actual IC. I cleaned it with cotton and water, as suggested, but that didn't correct the alignment issue.
The 385 error happened at 65084 prints followed by a 285 at 65125. Print counter is now at 65413 so it's been over 300 pages since the 385 error. How do I know if that error is "cleared" or is 385 a critical sensor failure?Comment
Since the ID sensors aren't throwing an error on boot after the self-test I'm going to assume they're okay. Here's a color print (arrow shows leading edge).
It shows solid and consistent CMYK coverage with the Yellow way out of alignment. At this point I'm thinking the various attempts to do a forced alignment with a ceased Yellow developer (which was probably the cause of the problem all along) has caused the Yellow developer stepping motor to get misaligned. In that case what the machine thinks is a certain point it's moving to isn't anymore causing alignment to fail. So close...Comment
Thanks for the heads-up. Got the new docs and they do include sections not in the version I've been using, including coverage of the ID sensors.
[ATTACH=CONFIG]50684[/ATTACH]
Hi folks - an issue came up over the weekend.
As already noted I replaced most everything in the machine except toner and it has been running fine. I did a large print run which consumed what was left of the black toner that has been in the machine for a decade now.
In anticipation of this I recently purchased a set of NIB Ricoh toner cartridges and replaced the black cartridge. After the replacement the printer started printing a black streak in the middle of the paper. The streaking appears on the OPC drum but not on the belt.
Since both the black OPC and developer have been recently replaced and were working fine prior to the new toner I'm wondering if it's the toner.
I tried cleaning the OPC drum and doing a toner refresh (sp3-921-001) but that didn't seem to help. Insights most welcome.Comment
Probably no. With some DVU you can get temporary clearing by turning the development gears backwards to rotate the clumps away from the doctor gap. With others you have to use a doctor blade cleaning tool. A2949590 Paper Dust Cleaner-5pcs/setComment
I checked and this is the case for all the developers. I carefully removed the foam goo which seems to have solved the problem. I'll know for sure after running more prints through.Comment
