Ricoh MP C3003 wiring harnesses part numbers
  • Will
    • Jun 2007
    • 171
    Does anyone know or have a separate parts catalog specially for the wiring harnesses for the MP C3003?
    The regular parts manual for this model which I already have doesn't list any of the wiring harnesses for
    this model machine. Looking for the HVPS harness and transfer wiring harnesses part numbers.
    • 37524
    Wiring harness part numbers can be found on the Point to Point diagram.
    • Will
      • Jun 2007
      • 171
      Ok I have both the service and parts manual, but don't see anywhere in either manual any wiring diagrams with point to point. Is there some sort of separate manual for that on the MP C3003? If so can anyone give me a copy of it?
        • 37524
        The point to point is a separate manual.PtoP-rfg057796.pdf
        • Will
          • Jun 2007
          • 171
          Thank you so much for the PDF on that. Maybe you can tell me if I'm missing something else. Have a MP C3003 with SC492 errors. When I look in the service manual they talk about possible wire harnesses that can cause it and to replace D1475365, D1475324, & D1475326, besides replacing the HVP.TTS, Transfer unit, & IOB PCB. Are you able to get those wire harnesses/cables and prices? Or can you tell me if there is a more common problem causing this error. Intermittently jams and according sheet is found in the vertical transport with an image and a solid black horizontal line across the sheet.
          • dalewb74
            • Feb 2018
            • 1155
            have you checked your connections?
            • anothertech
              • 1771
              What have you replaced so far?
