ricoh mpc3003 keep jam at duplex .....already check all output tray and all sensor ....anyone can help me ?
Ricoh MPC3003
Re: Ricoh MPC3003
fuser PM counts will effect double sided ? i 1st time repair this model ..newbie ..Comment
Re: Ricoh MPC3003
Is there drive to the black gear (on the right side of the door) if you stand in front of the door? Can you manually feed paper into the duplex while turning the black gear?
Sent from my SM-N770F using TapatalkPress the GREEN button!!Comment
Re: Ricoh MPC3003
What about the jam code. And I do not mean the letter code that tells the operator where to look for the jammed paper. I mean the numeric code that starts with the letter J and is followed by 3 digits.Comment
Re: Ricoh MPC3003
Is the junction gate solenoid moving in output mode? Had a lot of problem with exit units, paper feed IOB's and the side door harness on the older Metis.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Re: Ricoh MPC3003
[QUOTE=slimslob;1891187]
it seems to break down easily, it has already happened to me three, four times, I changed the whole paper output unit to do earlier, I had some machines available."I'll be back"Comment
