Ricoh MPC3003
  • Jeffery311
    • Jan 2020
    • 9
    [Jamming] Ricoh MPC3003
    ricoh mpc3003 keep jam at duplex .....already check all output tray and all sensor ....anyone can help me ?
  • davel
    • Oct 2011
    • 1093
    Re: Ricoh MPC3003
    Need a lot more info, jam code, fuser PM counts, SC codes, have you replaced any parts.
    • Jeffery311
      • Jan 2020
      • 9
      Re: Ricoh MPC3003
      single side no problem ....double side keep jam at duplex ....dont have any sc codes ...no replace part..
      fuser PM counts will effect double sided ? i 1st time repair this model ..newbie ..
      • Polarbear
        • Feb 2012
        • 1070
        Re: Ricoh MPC3003
        Is there drive to the black gear (on the right side of the door) if you stand in front of the door? Can you manually feed paper into the duplex while turning the black gear?
        Sent from my SM-N770F using Tapatalk
        Press the GREEN button!!
        • Jeffery311
          • Jan 2020
          • 9
          Re: Ricoh MPC3003
          • Polarbear
            • Feb 2012
            • 1070
            Re: Ricoh MPC3003
            Output test on duplex motor?
              • 37182
              Re: Ricoh MPC3003
              What about the jam code. And I do not mean the letter code that tells the operator where to look for the jammed paper. I mean the numeric code that starts with the letter J and is followed by 3 digits.
              • Jeffery311
                • Jan 2020
                • 9
                Re: Ricoh MPC3003
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: Ricoh MPC3003
                  Is the junction gate solenoid moving in output mode? Had a lot of problem with exit units, paper feed IOB's and the side door harness on the older Metis.
                  Hit it.
                  • Gift
                    • Mar 2011
                    • 2457
                    Re: Ricoh MPC3003
                    looks like my first 1 bin tray installation when I forgot that gear
                    J027 appears to be a duplex entrance late sensor error - does the paper reach that sensor? Can you test that sensor?
                    • Jeffery311
                      • Jan 2020
                      • 9
                      Re: Ricoh MPC3003
                      [QUOTE=Gift;1891003]
                        • 37182
                        Re: Ricoh MPC3003
                        [QUOTE=Jeffery311;1891005]Have you visually inspected the area where the lead edge is stopping at.
                        • luca72
                          • Oct 2017
                          • 1724
                          Re: Ricoh MPC3003
                          [QUOTE=slimslob;1891187]
                          it seems to break down easily, it has already happened to me three, four times, I changed the whole paper output unit to do earlier, I had some machines available.
                          • Jeffery311
                            • Jan 2020
                            • 9
                            Re: Ricoh MPC3003
                            • Jeffery311
                              • Jan 2020
                              • 9
                              Re: Ricoh MPC3003
                              [QUOTE=luca72;1891239]
