Ricoh MP C2500 Error Code SC672 on Startup.
  • DRichard
    • May 2008
    • 482
    #16
    Re: Ricoh MP C2500 Error Code SC672 on Startup.
    Originally posted by Polarbear
    In my experience this code generally means a controller replacement. Redoing thr connections won't hurt, but I can't recall once fixing that code without a replacement controller.
    Sent from my SM-N770F using Tapatalk
    ...nor I.
    "Enjoy every sandwich."
    -- Warren Zevon
    • Rada
      • Sep 2021
      • 9
      #17
      Originally posted by Gift
      Did you remove HDD and Ram at the same time? Not a good idea afaik..
      In case the unit has a java/vm card you can try and remove it, too.
      Dear Friends,
      I put back every thing to its place and only remove a Big SD Memory Card on the back of the machine. and machine take a long time on welcome screen and turned on and I tried to make a copy it was working fine. buts it was not going to printer and scanner mode. I tried 3 to 4 time by restarting the machine. every time it take long time to start. but not going to printer and scanner options. then I just leave it for a while. then I just put the USB cable in the printer to check didn't connect to my laptop. then I saw that screen and every thing is off. and only power light in on. then I tried to restart it. but every time only Power light is turning on nothing else. Can you tell me what is the problem.
      • Polarbear
        • Feb 2012
        • 1070
        #18
        Hi
        We're the switches on the controller board? Switch 1 dictates booting from flash memory if off or SD card when on.
        Switch 2 to 8 should not be changed.
        Did you change these with the machine powered on?
        Press the GREEN button!!
        • davel
          • Oct 2011
          • 1108
          #19
          The more you do without knowing what the heck you are doing the worse it will become. Put the old thing out of its misery and update to a newer model.
          • Rada
            • Sep 2021
            • 9
            #20
            Hi
            I Always turn power off before changing any thing. but once by mistake I didn't off the machine and change switch No. 8.
            • Rada
              • Sep 2021
              • 9
              #21
              Originally posted by Rada
              Dear Friends,
              Brothers Please guide me further. need your help.
              • TonerMunkeh
                Professional Moron
                • 3865
                #22
                As it has been such a long time since I have seen one of these things, does it have a printer / scanner SD card?
                Hit it.
                • Rada
                  • Sep 2021
                  • 9
                  #23
                  Yes.
