Ricoh MP C2500 Error Code SC672 on Startup.
  • Rada
    • Sep 2021
    • 9
    Hi Friends,
    I have a Ricoh MP C2500. When I m starting it, it is giving error SC672 on startup screen. after search on Google I tried to remove and reconnect HDD and RAM and restart it. but problem not solved. Can any one help me to remove this error? it is also not going to service mode. just stuck on startup screen.
  • Polarbear
    • Feb 2012
    • 1070
    Re: Ricoh MP C2500 Error Code SC672 on Startup.
    Sounds like your controller has called it a day.
    Sent from my SM-N770F using Tapatalk
    Press the GREEN button!!
    • Rada
      • Sep 2021
      • 9
      Tel me how can I fix this error? What should I do?.
        • 37480
        SC 672 is a communication error between the controller and the operation panel. It is usually caused by a bad connection. Disconnect and reconnect the harness going to the operation panel at both ends.
        • Polarbear
          • Feb 2012
          • 1070
          In my experience this code generally means a controller replacement. Redoing thr connections won't hurt, but I can't recall once fixing that code without a replacement controller.
            • 37480
            I have never had to replace the controller. It has always been the harness. With the newer models it is the USB cable.
            • copier tech
              • 8142
              Originally posted by Rada
              Hi Friends,
              Try to update the firmware if this fails replace the controller board.
              • bob marley
                • Jan 2012
                • 1339
                check the setting of SP5875-001. if the setting is set to 1 (OFF) change it to 0 (OFF).
                Live for yourself and you will live in vain. Live for others, and you will live again
                • anothertech
                  • 1768
                  What is that setting labeled? and how to set from off to off?
                    • 37480
                    Since you are already getting the SC code, SP 5875 will just make things worse.
                    • davel
                      • Oct 2011
                      • 1103
                      Machine is very old, only hope is get a controller from a parts machine but I assume you are not an experienced tech so may be you need to buy a replacement machine.
                      • Gift
                        • Mar 2011
                        • 2459
                        Did you remove HDD and Ram at the same time? Not a good idea afaik..
                        In case the unit has a java/vm card you can try and remove it, too.
                        • luca72
                          • Oct 2017
                          • 1775
                          Hi Friends,
                          try to disconnect and reconnect the controller and its connectors, try to turn on the machine with the hdd disconnected, but it is easy for it to be the failed controller
                          "I'll be back"
                          • Rada
                            • Sep 2021
                            • 9
                            Thank you All for your Great help. I Tried things that you mentioned above but problem was the same. but Suddenly I saw a switch board (Picture is attached) that have a 8 switches. all are upside but switch number 1 and 8 was down. I turn them up one by one. now the situation is that when move both switch up(1&8) the same error comes SC672. But when I move down the switch number 1 only print start and then give a new Error SC819 (Picture is attached). and I like to tell you that at the start of problem it starts with this same error (SC819). Sc672 come letter. now its back to SC819. Please guide me.
                            • copier tech
                              • 8142
