Ricoh MP C2500 Error Code SC672 on Startup.
Re: Ricoh MP C2500 Error Code SC672 on Startup.
I put back every thing to its place and only remove a Big SD Memory Card on the back of the machine. and machine take a long time on welcome screen and turned on and I tried to make a copy it was working fine. buts it was not going to printer and scanner mode. I tried 3 to 4 time by restarting the machine. every time it take long time to start. but not going to printer and scanner options. then I just leave it for a while. then I just put the USB cable in the printer to check didn't connect to my laptop. then I saw that screen and every thing is off. and only power light in on. then I tried to restart it. but every time only Power light is turning on nothing else. Can you tell me what is the problem.Comment
Hi
We're the switches on the controller board? Switch 1 dictates booting from flash memory if off or SD card when on.
Switch 2 to 8 should not be changed.
Did you change these with the machine powered on?
Sent from my SM-N770F using TapatalkPress the GREEN button!!Comment
I Always turn power off before changing any thing. but once by mistake I didn't off the machine and change switch No. 8.Comment
Dear Friends,
As it has been such a long time since I have seen one of these things, does it have a printer / scanner SD card?It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
