Ricoh aficio mp c4504ex mancano le app
  • reddevils24
    • Sep 2024
    • 9
    Buongiorno, sono nuovo del forum
    Ho un problema con una ricoh aficio mp c4504 acquistata già senza app. C'è un modo per ripristinare pare all' originale?
    Sicuramente qualche tecnico ha messo le mani prima di noi, poichè ci sono altri problemi con le schermate che alcune sono in italiano altre in inglese.
    Potete aiutarmi?
  • GIUBOSS
    • 1435
    Potete aiutarmi?
    Hi, first of all you have to write in English.
    Or to erase all memory...
    1Disconnect the communication cables from the machine.
    2Authenticate as the machine administrator via the control panel.
    3Press [System Settings].
    4Press [Administrative Tools].
    5Press [DownNext Arrow] twice.
    6Press [Delete. all memory].
    • reddevils24
      • Sep 2024
      • 9
      Hello, I'm new to the forum I have a problem with a Ricoh Aficio MP C4504 purchased without an app. Is there a way to restore it to the original? Surely some technician has put their hands on it before us, since there are other problems with the screens that some are in Italian others in English. Can you help me?
      • reddevils24
        • Sep 2024
        • 9
        I get the error that I don't have the privileges to perform this operation
          • 37488
          You failed to do step 2 properly.
          • reddevils24
            • Sep 2024
            • 9
            I tried to update the firmware using the ricoh firmware update tools, but I get the error "cannot be update because it contains a custom module"
              • 37488
              The "custom module" is probably something industry specific for the previous owner. See if you can export the Diagnostic report SP5-992-004 to an SD card or USB drive and then upload it here for us to look at. We should be able to identify the custom module so that you can replace it with the standard module.
              • reddevils24
                • Sep 2024
                • 9
                here, i finally did it. How can I attach the csv file if the forum doesn't allow it? I'll post the link for you https://we.tl/t-GOhO7FUBU7
                  • 37488
                  I asked for the diagnostic report, SP5-992-004. It should export as a PDF. Either that or print SP5-990-004 and scan it to a pdf.
                  • reddevils24
                    • Sep 2024
                    • 9
                    here is the report in pdf
                      • 37488
                      Well now you know how to attach a pdf but that is still NOT THE DIAGNOSTIC LOG. The Diagnostic Log is a list of all firmware and their version numbers.
                      • reddevils24
                        • Sep 2024
                        • 9
                        I did what you asked me to do. Sp5-990-004
                          • 37488
                          Negative! That was the Data Log SP 5-990-002.
                          • reddevils24
                            • Sep 2024
                            • 9
                            The diagnostic test in this equipment was sp5-990-005. here is what you asked me
                              • 37488
                              Looks like the Network Support module is a custom firmware. copier tech in London might be able to help you with the individual module firmware.
